Service Status NOT FOUND
Re: Service Status NOT FOUND
I download 04.4.23 installed and my Nagios still thinks it has 4.1.73 installed
Do I need to uninstall restart then install what a good process for updating the nsclient?
Tom
Tom
I would uninstall the old nsclient completely (delete the folder out of program files to ensure it's clean), and then reinstall. If it's still reporting the old version, then a complete reinstall may be needed, or simply a restart of the nscp service.
I have restarted the server a few times no change.
So off to an uninstall
but first I will save my nsclient.ini
After uninstalling
then restarted
deleted the folder nsclient++
installed new version
Restarted again
Nagios still thinks it has the old nsclient still
Not reporting correctly here whats up?
then restarted
Restarted again
Are you trying to monitor a device behind NAT by chance? Are you able to see the device go down when it was deleted / uninstalled?
Please run this on the Windows machine and post the full output -
Additionally, please post your nsclient.ini and nsclient.log file for us to review, as well as the full output of your testing over the CLI showing the wrong version.
dir "c:\Program Files\NSClient++"
ipconfig
see attached
This is not a network issue again I must repeat myself this same server has approx. 70 srvices I am checking in Nagios and only three of them fail
Very strange indeed.
list.txt- info asked for
- (49.91 KiB) Downloaded 361 times
To the one who told me to upgrade the nsclient
That suggestion foobared my nsclient ini and the new version is empty
I had a lot of custom entries to make checks from other plugins to work.
Also Nagios is not even seeing this change
Need help on this asap
avandemore
Have you considered using NCPA?
https://www.nagios.org/ncpa/help.php
We don't write or maintain NSClient so helping with advanced configurations is somewhat beyond the scope of what we can help with here.
Previous Nagios employee
To All
This is not a nsclient issue it is a Nagios issue
I do not understand why no one on here knows what is wrong.
I have many machines running same nsclient version and have no issues
I need someone to figure this out please help
Not going to switch to something else when what is going on here is Nagios related.
Also why does Nagios not pick up the new version of nsclient
Still claims it is running 4.1.73
host_name TGCS006
service_description NSClient++ Version
servicegroups nsclients
check_command check_nt!CLIENTVERSION
When you uninstalled the NSClient++ service, was it still reporting the version? If so, it's possible you have the process open on the Windows machine.
If you're positive this is Nagios related - please post the EXACT commands you're running, as well as ALL related objects. This includes the command, host, and service. We should then be able to setup a test on our end to replicate it.
