Problem SNMP UNKNOWN
sofiane
Re: Problem SNMP UNKNOWN
Post by sofiane »
rhassing wrote:.1.3.6.1.2.1.1.3.0 would be a full OID
Result :
SNMP OK - Timeticks: (380169) 1:03:21.69 |
rhassing
Post by rhassing »
And what happens if you do
check_snmp -m ALL -H localhost' -C public -o sysDescr.0
Rob Hassing
sofiane
Post by sofiane »
Result :
SNMP OK - Linux Sofiane 4.9.0-4-amd64 #1 SMP Debian 4.9.65-3 (2017-12-03) x86_64 |
rhassing
Post by rhassing »
So it should work in Nagios as well...
This is the command from your command.cfg file
Rob Hassing
sofiane
Post by sofiane »
I don't know why, but it still doesn't work :?
kyang
Post by kyang »
Wow, thanks @rhassing!
sofiane, it doesn't work? Same error as the first screenshot?
Were there any changes to the commands.cfg? Or is it still the same?
Is the path to check_snmp plugin actually this /usr/lib/nagios/plugins/check_snmp?
sofiane
Post by sofiane »
kyang wrote:Wow, thanks @rhassing!
I'm so boring ? :lol:
Yes, unfortunately :|
The same
Yes.
Another reason for the errors you are receiving is that the SNMP Daemon that is running on the server is not allowing the polling of those OID's so can you post your snmpd.conf file so we can check it?
sofiane
Post by sofiane »
Sorry for my inactivity, I had some problems IRL
After reinstalling Nagios, all my snmp services have now "critical" status and graphs don't work (better than "unknown" I agree :mrgreen: )
I don't now why, but "SNMP_service.xml" doesn't want to be created in /usr/local/pnp4nagios/var/perfdata/localhost/ , even after restarting npcd service
Check and see if after reinstalling Nagios, the check_snmp plugin was reinstalled as well in to the following location.
If the plugin is missing, that would generate the error you are receiving.
