Waiting for configuration verification stuck
emsadmin
Re: Waiting for configuration verification stuck
Post by emsadmin »
npolovenko wrote:@emsadmin, In Nagios XI web browser interface please navigate to the Configure -> Core Configurations Manager menu. In the left column under Tools select Config File Management. In that menu please click, in order 1) Write Configs 2)Delete Files 3) Write Configs(yes, again) 4) Verify Files. Next, in the left column under Quick tools you'll find the Apply Configuration menu, go there and click on Apply Configuration button.
https://support.nagios.com/kb/article.php?id=144
Did that solve the problem?
Thank you. Unfortunately it doesn't help, but I always got the same failed message, please refer to the attached pictures.
I guess that is the stopping point.
Post by dwhitfield »
Are you a customer by chance? If so, at this point you should probably open a ticket at https://support.nagios.com/tickets/
If you are a prospective customer, you will probably want to reach out to our pre-sales team at https://www.nagios.com/services/quickstart/
