This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
Post
by scottwilkerson »
This actually all looks good, can you try to apply configuration from the web UI and if you get an error, send us the contents of
/usr/local/nagiosxi/var/cmdsubsys.log
smapple
Post
by smapple »
I tried to apply the configuration if gave the error.
The log file just has this:
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
PROCESSED 0 COMMANDS
I opened the file and check to see many lines " PROCESSED 0 COMMANDS"
nothing other than this
Post
by scottwilkerson »
Please PM me your system profile.zip from Admin -> System Profile
Also the results of
grep nagios /var/log/cron|tail -20
smapple
Post
by smapple »
Jun 28 13:08:01 nagios3 CROND[29080]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29081]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29084]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29082]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29083]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29086]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29078]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29085]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29079]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 28 13:08:01 nagios3 CROND[29087]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29471]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29472]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29473]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29475]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29474]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29477]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29476]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29480]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29483]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 28 13:09:01 nagios3 CROND[29488]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
[sadmin@nagios3 scripts]$
smapple
Post
by smapple »
PROFILE BUILD FAILED
Array
CODE: 1
When I try to build profile its throws the above error
Post
by scottwilkerson »
Please open a ticket in our Support center and reference this thread.
https://support.nagios.com/tickets/
We are likely going to have to setup a remote session to take a look at this system.
smapple
Post
by smapple »
I have raised the support ticket:
#487990 - ticket number.
what are the next steps?
Where do I share the contact number?
Post
by scottwilkerson »
Closing thread, will be continued in ticket
Post
by scottwilkerson »
Updating with resolution
Selinux was enabled, the following solved the issue
sed -i 's/SELINUX=.*/SELINUX=disabled/g' /etc/selinux/config
setenforce 0
