The check_nrpe_HPUX command! Check_pip_err_rel_ECE !!!!!!! was executed on an HPUX which has not been updated the NRPE so I use an old version of it to be executed on those computers.
It was done in this way to eliminate these lines:
check_nrpe: Remote 10.177.100.24 does not support Version 3 Packets
In the /var/log/messages
In effect, we have discovered that you are correct, the tee command is the one that prevents the alert from being sent as CRITICAL.
Thank you very much for your help.
Best regards
Instead of marking error as critical in red, put it as Ok an
fraguillen
Re: Instead of marking error as critical in red, put it as O
Glad you discovered the issue.fraguillen wrote:In effect, we have discovered that you are correct, the tee command is the one that prevents the alert from being sent as CRITICAL.
Locking thread
