Instead of marking error as critical in red, put it as Ok an
fraguillen
Good Morning
I have this problem:
I have a script that returns a value that is related to the status of a service, Ok, warning or critical, the problem is that it indicates any of those states but in the Nagios XI interface it always indicates it to me as OK and in red color but in the status column of the information I
shows as Error.
This is script:
STATE_CRITICAL=2
STATE_OK=0
process="$1"
if [ $(hostname) = "sclc-omc01-prod" -o $(hostname) = "sclc-omc02-prod" ] ; then
CANT=$( ps -fu oracle| grep -v grep | grep -c "$process" 2> /dev/null)
if [ $CANT -gt 0 ]; then
echo "OK: Se encuentra activo el proceso: $process"
Status=$STATE_OK
else
echo "ERROR: Se encuentra caido el proceso, favor revisar para levantar: $process";
Status=$STATE_CRITICAL
fi
else
echo "ERROR: No se encuentra correctamente configurada la alarma, solo corre en el servidor sclc-omc01-prod o sclc-omc02-prod";
fi
echo "=======fin======="
exit $Status
Best regards...
shows as Error.
This is script:
STATE_CRITICAL=2
STATE_OK=0
process="$1"
Status=$STATE_OK
else
fi
else
fi
exit $Status
Best regards...
Re: Instead of marking error as critical in red, put it as O
Can you run the script as it would be run from the CLI and then run
Please show the output
echo $?-
fraguillen
[root@prod libexec]# ./check_val_process_bash LDM_Worker_check.sh
ERROR! Se encuentra caido el proceso, favor revisar para levantar: LDM_Worker_check.sh
=======fin=======
[root@prod libexec]# echo $?
2
=======fin=======
2
Is this consistent with what It is displaying in the UI?
Also, do you get the same results if you run this as the nagios user?
su nagios
echo $?-
fraguillen
In the UI in the column Status shows OK in green, but in the column Status Information shows:
[nagios@prod libexec]$ whoami
nagios
[nagios@prod libexec]$ ./check_val_process_bash LDM_Worker_check.sh
=======fin=======
[nagios@prod libexec]$ echo $?
2
nagios
=======fin=======
2
Are you sure you are looking at the service and not the OK for the host?fraguillen wrote:In the UI in the column Status shows OK in green, but in the column Status Information shows:
If you drill into the service details (click service name) does it show CRITICAL?
fraguillen
How can I upload an image?
Underneath the submit button on the forum is an "Upload attachment" tab, click that
select the file
Click the "Add the file" button
select the file
fraguillen
Attached image of Nagios XI
I just looked at your script again and it is possible you are missing a new line at the end of the script
May I suggest the following modifications
STATE_CRITICAL=2
STATE_OK=0
process="$1"
exit $STATE_OK
else
exit $STATE_CRITICAL
fi
else
fi
