Check_VMWARE_API Plugin not working
Re: Check_VMWARE_API Plugin not working
The check worked for you, didn't it?
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H MYHOST-3 -u root -p "###############" -l runtime -s status
CHECK_VMWARE_API.PL OK - overall status=green
Are you running the plugin against different servers? Is MYHOST-3 different than myhost-2? Can you ping myhost-2? Is there a firewall in between? What is the output of the command below?
nmap myhost-2 -p 443
Some people reported issues with this plugin with unsigned certificates. I am not sure if this is the case here, but you could try an easy "workaround". Open the plugin in a text editor and add this as the first line (after the comments):
$ENV{PERL_LWP_SSL_VERIFY_HOSTNAME} = 0;
Save, exit, and try your check again.
kwhogster
Post by kwhogster »
1, yes the checked worked the first time on myhost-3 now it timesout.
2. I ran this against all my hosts I have 9 of them to see if it worked all the same timeout.
3. root@tgcs017:/usr/local/nagios/etc/objects/linuxservers# nmap myhost-2 -p 443
Starting Nmap 7.01 ( https://nmap.org ) at 2019-03-15 11:56 EDT
Nmap scan report formyhost-2 (10.2.8.60)
Host is up (0.00036s latency).
rDNS record for 10.2.8.60: myhost-2.my.network.com
PORT STATE SERVICE
443/tcp open https
MAC Address: 78:2B:CB:05:4C:38 (Dell)
4. I added $ENV{PERL_LWP_SSL_VERIFY_HOSTNAME} = 0;
check VMware api
check VMware api
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H myhost-2 -t 50 -u root -p "#########" -l runtime -s status -vvv
[extra-opts] check_vmware_api.pl -H myhost-2 -t 50 -u root -p ########### -l runtime -s status -vvv
CHECK_VMWARE_API.PL UNKNOWN - plugin timed out (timeout 50s)
Same results after adding the code.
It is really strange that the check initially worked, and now it is timing out...
Does it make any difference if you use an IP address in your command instead of a hostname?
What is the OS/distro that you are using? What is the version of the ESXi/Vspher server that you are monitoring? What is the output of the following command?
cat /proc/sys/kernel/random/entropy_avail
I found some reports on plugin's timeouts as this one:
https://github.com/op5/check_vmware_api/issues/17
You could try "check_esx3-05.pl" plugin as an alternative. It's a bit older, but it may work in your environment.
https://exchange.nagios.org/directory/P ... st/details
So far, I haven't been able to recreate the issue in-house. Unfortunately, the "verbose" output is not verbose at all, and it's not helping us either. :(
kwhogster
Post by kwhogster »
root@tgcs017:/usr/local/nagios/libexec# cat /proc/sys/kernel/random/entropy_avail
170
The other check gives this error
root@tgcs017:/usr/local/nagios/libexec# ./check_esx3.pl
Can't locate Nagios/Plugin.pm in @INC (you may need to install the Nagios::Plugin module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.22.1 /usr/local/share/perl/5.22.1 /usr/lib/x86_64-linux-gnu/perl5/5.22 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.22 /usr/share/perl/5.22 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base .) at ./check_esx3.pl line 31.
This is line 31
use Nagios::Plugin;
cdienger
Post by cdienger »
Open check_esx3.pl in vi or another editor and check out line 31. It probably looks like:
use Nagios::Plugin;
Change it to:
use Nagios::Monitoring::Plugin;
There may be other lines in the script that need similar changes as well to point to the Nagios plugin module.
Nagios::Plugin has been replaced with Nagios::Monitoring::Plugin, so you would need to modify again the plugin.
Make a copy of the old plugin:
cp -p /usr/local/nagios/libexec/check_esx3.pl /usr/local/nagios/libexec/check_esx3.pl.backup
then run:
sed -i 's/Nagios::Plugin/Nagios::Monitoring::Plugin/g' check_esx3.pl
or you could modify your plugin manually as suggested by @cdienger.
Try your check again.
kwhogster
Post by kwhogster »
I found two places line 31 and line 99
I then tested all the command on all my hosts
All worked but one the VMFS check line 812 was another one.
My search ability in VI is not the best I am a Windows GUY LOL
Do you know of any other places in the script I may need to change?
cdienger
Post by cdienger »
There are a few other places. I've attached a modified script here.
check_esx3-0.5.pl
(133.09 KiB) Downloaded 767 times
kwhogster
Post by kwhogster »
That worked great
Have one issue on one ESXI Host
Host: TGCSESXI-1
Service: ESXI VMFS Check
Status: CRITICAL
Last check: 04-05-2019 10:33:26
Duration: 0d 10h 37m 11s
Attempt: 3/3
Status information: (Service check timed out after 120.01 seconds)
run this
./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##########" -l vmfs
My check
        service_description     ESXI VMFS Check
        host_name               hostname
        check_command           check_esx3!root!#########!vmfs
        initial_state           u
        max_check_attempts      3
        notification_interval   1440
        check_interval          1440
        retry_interval          3
        active_checks_enabled   1
        check_period            24x7
        servicegroups           VMWarevmfs
        register                1
My command
        command_name check_esx3
        command_line $USER1$/check_esx3.pl -H $HOSTADDRESS$ -u $ARG1$ -p "$ARG2$" -l "$ARG3$"
The exact same check and command are working on 8 other ESXI hosts no problem.
Just this one ESXI Host the error as above.
Any thoughts?
Tom
Is this the same version of ESXi/VSphere server as the rest of them (that are working)? Are the permissions of the user the same? Do any other checks work?
Try running:
./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##########" -l RUNTIME
./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##########" -l CPU
./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##########" -l MEM
Do you see the datastores when you log in the server with the same credentials?
