If you have an error in the configuration database, you can find those with the following procedure.
Run through the following steps in Configure > CCM > Tools > Config File Management to resolve configuration errors.
1. Delete Files
2. Write Files
3. Verify Files ( if you see any errors follow the message to correct and repeat steps 1-3 until it passes)
4. Restart Nagios Core
