Exclude state=0 from api call
Hi
I try to do a report from api and i need to exclude state=o from objects/statehistory i only wanna se values 1, 2 and 3
Thanks for your help
Re: Exclude state=0 from api call
Hello
i can do it with
Now a have another question:
in objects/hostavailability how can i set the starttime from a specific date for example 25/10/2021 to another dat for example 25/11/2021
i can do it with
curl -XGET "https://XISERVER/nagiosxi/api/v1/objects/statehistory?apikey=XXXXXXXXXXXXXXXXXXXXXXXX&pretty=1&state_type=1&state=in:1,2,3"
Hi
This should help: You can find the API documentation by going to the Help page on your XI server: Thanks
Hi gsmith
It uses epoch time, actully i use the powerbi for advanced reports and dashboard, Nevertheless i need to generate a dinamic ability report for some time periods as las 7 days, las 30 days, this month, last mont.
I cant do the expresions in bash
but this expresion only runs on bash but in powerbi how i can generate this expressions with the link and it will be dinamic?
for example
curl -XGET "https://URL/nagiosxi/api/v1/objects/hos ... ]lastmonth[/b]"
Thanks for you help
curl -XGET "https://URL/nagiosxi/api/v1/objects/hostavailability?apikey=APIKEY&pretty=1&host=FLD0013_Puesto_de_Trabajo_PC1&starttime=$(date +'%s' --date='31 days ago')"
for example
Thanks for you help
Hi
I don't use power bi so I can't really answer your question.
Do you need to know how to get today's date/time in bash, and calculate the epoch time for 7
days ago?
days ago?
Hi power bi only need a Url
But when i make the url with the epoch, tomorrow will be from 8 days ago, i need a expresion as:
Hi Don,
So the default end time is now, so determine the timestamp based on now - 30 days.
Current time = 1638225150
1 month = 2629743 seconds
30 Days ago = 1638225150 - 2629743 = 1635595407
starttime = 1635595407
Sample command from my test system would be:
Hopefully, that helps. If not, please provide some more context as we may not be understanding the issue correctly. Thanks, Benjamin
References:
https://www.epochconverter.com/
https://www.unixtimestamp.com/
curl -XGET "https://192.168.23.112/nagiosxi/api/v1/objects/hostavailability?apikey=AAXHBIAkAHq5L7nnrHdgah5RKMi7b4uKDrIrqu5ZcukdFKTmH7FRnZInLhtdk0dd&pretty=1&host=localhost&starttime=1635595407"
References:
Hi dear Benjamin
Thx for you reply
If i use your method tomorrow will be 31 days 8 days 1 month 1 day.
I need that our parameter allways be 1 week, 1 month, last month, this month. For reporting without change the paremeters in the api.
Greetings
Thx for you reply
Greetings
HI,
Regards,
Benjamin
Reference:
https://www.epochconverter.com/timestamp-lis
The API is using unix timestamps for start and end times, so determining the UNIX timestamp start/endpoints for the last month would have to be done in the script your using to manage the API. Unfortunately, It doesn't have the functionality built-in.I need that our parameter always be 1 week, 1 month, last month, this month. For reporting without change the paremeters in the api
Regards,
Benjamin
Reference:
Greetings
Ok, then what is the limit of records from api reply
https://XISERVER/nagiosxi/api/v1/object ... b]XXXXXXXX[/b]
