Trouble getting LDAP wizard to work
benningtonr
Re: Trouble getting LDAP wizard to work
Post by benningtonr »
C:\Users\ronb>ping nagios.whro.local
Pinging nagios.whro.local [192.168.99.69] with 32 bytes of data:
Reply from 192.168.99.69: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.99.69:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
yancy
Post by yancy »
At this point, it looks like you have an issue with your Windows domain controller. Perhaps your OU nesting isn't correct. Do you have a different account you can test against?
benningtonr
yes
benningtonr wrote:yes
You can try testing with the other as yancy suggested however, as he pointed out
yancy wrote:At this point, it looks like you have an issue with your Windows domain controller. Perhaps your OU nesting isn't correct?
Until this is fixed the check plugin likely will not work
benningtonr
it worked before we migrated over to a VM
yancy
Post by yancy »
benningtonr,
It worked before you moved your domain controller to a VM, or Nagios to a VM?
I compiled a document that will help. Give this a shot using the administrator account.
http://assets.nagios.com/downloads/nagi ... h_LDAP.pdf
benningtonr
That's what i needed, directions worked perfectly.
Thank you
