No forgiveness needed, it is rather absurd, and thankfully not due to us! Along the same lines, you definitely need to change back to our version of snmptt, we have it compiled with certain flags for use with nagios. It shouldn't have any dependencies and should be as easy as the commands below:
[root@LkennagiosT01 tmp]# ll /var/spool/snmptt/
total 0
total 4
-rw-r--r-- 1 root root 304 Aug 22 15:31 #snmptt-trap-1377199899334997
So the snmptt and snmpttunknown still are empty after sendint the test trap, but this is better than yesterday!
if this update is an problem you guys might want to put a warning out there or "in the nagios announcements when you login) or a sticky warning ppl.
Or your gonna get flooded.
But then again nobody is dumb enough to apply an update to snmp before looking at its changelog...oh wait...
Did you alter the snmptt.ini again to be in daemon mode? I'm guessing the rpm overwrote anything already there.. But otherwise thats great that they are coming in again!
[root@LkennagiosT01 ~]# service snmpd restart
Stopping snmpd: [ OK ]
Starting snmpd: [ OK ]
[root@LkennagiosT01 ~]# service snmptt restart
Stopping snmptt: [ OK ]
Starting snmptt: Did not find 'mib-2' in module SNMPv2-SMI-v1 (/usr/local/share/snmp/mibs/host-resources-mib.mib)
Unlinked OID in HOST-RESOURCES-MIB: host ::= { mib-2 25 }
Undefined identifier: mib-2 near line 109 of /usr/local/share/snmp/mibs/host-resources-mib.mib
Did not find 'hrMIBAdminInfo' in module HOST-RESOURCES-MIB (/usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt)
Did not find 'hrStorage' in module HOST-RESOURCES-MIB (/usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt)
Did not find 'hrDevice' in module HOST-RESOURCES-MIB (/usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt)
Unlinked OID in HOST-RESOURCES-TYPES: hostResourcesTypesModule ::= { hrMIBAdminInfo 4 }
Undefined identifier: hrMIBAdminInfo near line 7 of /usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt
Unlinked OID in HOST-RESOURCES-TYPES: hrFSTypes ::= { hrDevice 9 }
Undefined identifier: hrDevice near line 226 of /usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt
Unlinked OID in HOST-RESOURCES-TYPES: hrDeviceTypes ::= { hrDevice 1 }
Undefined identifier: hrDevice near line 108 of /usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt
Unlinked OID in HOST-RESOURCES-TYPES: hrStorageTypes ::= { hrStorage 1 }
Undefined identifier: hrStorage near line 37 of /usr/local/share/snmp/mibs/HOST-RESOURCES-TYPES.txt
[ OK ]
[root@LkennagiosT01 ~]# service snmptrapd restart
Stopping snmptrapd: [ OK ]
Starting snmptrapd: [ OK ]
How about if I just tar up the mibs folder on my machine and we can go from there?!
Try untarring this and placing it in /usr/share/snmp. You probably will need to chown to root.nagios and chmod to 664.
Would it be a bad idea to uninstall:
snmpd
snmptt
snmptrapd
and net-snmp
and then run Scott''s script?
I haven't done it, just askin'
Or should I force the install of the old versions? I think that when you reinstall snmptt it forces the new ver down yah throat.
snmpd
snmptt
snmptrapd
and net-snmp
I am kinda confused here, maybe not enough coffee, where did scott come into play here? I see no issues with doing these steps Although really its just:
yum --nogpgcheck localinstall snmp-nagios.rpm-thingy (not real name:) and this is done already)
yum install net-snmp net-snmp-utils net-snmp-perl net-snmp-libs (as a note, I have version 5.5-44)
something/something/scotts-script
