recieving SNMP traps
benhank
Post by benhank »
Ok fellas I have tried to sort this one out myself, with my typical results : epic fail...
The initial issue, recorded in my award winning (#1 has no clue sys admin) post:
http://support.nagios.com/forum/viewtopic.php?f=16&t=11418
have all been resolved. I had to reinstall the net-snmp and all the other stuff.
then I followed the instructions detailed in
Nagios XI – Integrating SNMP Traps
AND the NSTI install document.
Every thing seems to have set up correctly as I had zero issues with installing my mibs, and restarting the snmptt snmptrapd services. The issue is i set up 2 sending servers, on is a nagios box and the other a windows box.
Prior to my reinstall the snmpunknown.log and the snmptt.log both had recorded data.
Now, I get nuthin' the log files aren't even created.
I disabled my iptables just in case,.. but my server just somehow isnt receiving the traps like it used to. I know I must be missing a step, I just cant figure out what it is....
Proudly running:
Nagios Network Analyser
Nagios Fusion
abrist
Red Shirt
Re: recieving SNMP traps
Post by abrist »
First question:
I presume that snmptt is running?
service snmptt status
Are the traps coming in as unconfigured objects the XI interface?
Have you checked to make sure that you nagios server did not get a different ip lease when you reinstalled the server? if so, did you change the remote devices to send to the new ip?
benhank
Post by benhank »
[root@LkennagiosT01 ~]# service snmptt status
snmptt (pid  2919) is running...
the IP is still the same, and the service check is not in unconfigured objects.
here is the service setup for the server:
	host_name			wkensimp02.healthone.org
	service_description		Passive Service
	use				xiwizard_passive_service
	max_check_attempts		1
	check_interval			1
	retry_interval			1
	check_period			xi_timeperiod_24x7
	notification_interval		60
	notification_period		xi_timeperiod_24x7
	contacts			nagiosadmin
	stalking_options		n
	_xiwizard			passivecheck
	register			1
	service_description		SNMP Traps
	use				xiwizard_snmptrap_service
	check_interval			1
	retry_interval			1
	notification_interval		1
	_xiwizard			snmp_trap
	register			1
	service_description		snmptrapd
	check_interval			1
	retry_interval			1
	stalking_options		n
	register			1
# Service configuration file
# END OF FILE
and the other:
	host_name			lkennagiosp03.healthone.org
	check_interval			1
	retry_interval			1
	stalking_options		n
	register			1
	check_interval			1
	retry_interval			1
	_xiwizard			snmp_trap
	register			1
	check_interval			1
	retry_interval			1
	stalking_options		n
	register			1
	service_description		snmptt
	check_interval			1
	retry_interval			1
	stalking_options		n
	register			1
# END OF FILE
Proudly running:
Nagios Fusion
sreinhardt
-fno-stack-protector
Post by sreinhardt »
You should definitely be able to see logging in both flat files and the database for nsti. As a check, you are not seeing them via nsti either correct? Another point, is that snmp traps rely on three services, snmpd, snmptt, and snmptrapd. If you have imported mibs since this stopped working, lets make sure all are working correctly.
service snmpd restart
service snmptt restart
service snmptrapd restart
I always restart them in this order, that is not to say that it makes a huge difference. Two other things we can check, is to nmap from another device and to tcp dump on the nagios server.
nmap -sU -p 162 [nagios server IP]
tcpdump -i eth0 dst port 162
benhank
Post by benhank »
I am not using nsti, i am using the snmptrap wiz and the passive check wiz. however:
Son of a Biskit! i did what you said and everything restarted ok:
Last login: Mon Aug 19 15:32:47 2013 from 172.26.68.146
[root@LkennagiosT01 ~]# service snmpd restart
Stopping snmpd:                                            [  OK  ]
Starting snmpd:                                            [  OK  ]
[root@LkennagiosT01 ~]# service snmptt restart
Stopping snmptt:                                           [  OK  ]
Starting snmptt:                                           [  OK  ]
[root@LkennagiosT01 ~]# service snmptrapd restart
Stopping snmptrapd:                                        [  OK  ]
Starting snmptrapd:                                        [  OK  ]
but still no logs =(
Then I noticed on my receiving server nagios displays the following on localhost:
localhost  HTTP
Warning 	12d 23h 49m 28s 	4/4 	2013-08-20 11:17:50 	HTTP WARNING: HTTP/1.1 403 Forbidden
on a whim I tailed the error log and got this:
[Tue Aug 20 11:13:41 2013] [error] [client 172.22.3.18] Directory index forbidden by Options directive: /usr/local/nagiosti/nsti/
I'd tried to install NSTI and ran into the django error as recorded here:
http://support.nagios.com/forum/viewtopic.php?f=22&t=11554
Any suggestions bro?
is it possible to uninstall nsti? or is there another way to fix this?
Proudly running:
Nagios Fusion
sreinhardt
You can certainly remove the /usr/local/nagiosti or /usr/local/nsti, depending on which version was installed. Otherwise it truely doesn't matter much as long as the daemon isn't running. Could you tar up the /etc/snmp folder and all contents, and pm me. It likely contains some private info that I wouldn't want widely posted.
benhank
Post by benhank »
sure !
Proudly running:
Nagios Fusion
sreinhardt
Couple changes that need to be made:
snmptt.ini:
mode = standalone TO mode = daemon
Might also turn on debugging to help
DEBUGGING = 1
DEBUGGING_FILE = /var/log/snmptt/snmptt-debug.log
Of course, restart all three snmp services after these changes.
Also lets check permissions on a few things:
ll /var/spool/snmptt/
ll /etc/snmp/
benhank
Post by benhank »
ok so there was a difference this time
Last login: Tue Aug 20 14:04:06 2013 from 172.26.68.146
Starting snmptt: PID file: /var/run/snmptt.pid   <<-----this is different than before
                                                           [  OK  ]
and
returned (a hundred or so, I just took a few.
-rw-r--r-- 1 root root 304 Aug 20 12:19 #snmptt-trap-1377015546835887
-rw-r--r-- 1 root root 828 Aug 20 13:01 #snmptt-trap-1377018082888443
-rw-r--r-- 1 root root 306 Aug 20 14:01 #snmptt-trap-1377021679597269
and finally:
[root@LkennagiosT01 ~]# ll /etc/snmp/
total 2836
-rw-r--r--  1 root   root     18861 Aug 12 10:46 snmpd.conf
-rw-r--r--  1 root   root        74 Aug 13 16:06 snmptrapd.conf
-rw-r--r--  1 root   root        67 Aug  7 12:38 snmptrapd.conf.rpmsave
-rw-r--r--  1 root   root      3909 Aug 19 12:45 snmptt.conf
-rw-r--r--. 1 root   root      2303 Mar 24  2003 snmptt.conf.rpmnew
-rw-r--r--  1 root   root   1216001 Aug  7 12:37 snmptt.conf.rpmorig
-rw-r--r--. 1 root   root   1583817 Aug  6 13:16 snmptt.conf.rpmsave
-rw-rw-r--  1 apache nagios   26025 Aug 20 14:09 snmptt.ini
-rw-rw-r--. 1 apache nagios   26690 Aug  6 13:16 snmptt.ini.rpmsave
Proudly running:
Nagios Fusion
sreinhardt
Future trap spools should be created as snmp user, however for now this is also going to be a part of the issue. (don't worry, snmp is certainly anything but "simple") Let's try changing permissions and see if that changes anything for getting things rolling. Fair warning, you may have to simply delete those current spools if this doesn't work.
chmod -R root.snmptt /var/spool/snmptt/
restart services, agian... yes this has to be done just about any time anything changes with snmp stuff.
Check logs
tail -f /var/log/snmp/snmptt.log
tail -f /var/log/snmp/snmpttunknown.log
Also since I forgot to add it, lets check your log permissions just to be sure:
ll /var/log/snmptt/
