CentOS errors
Re: CentOS errors
Post by slansing »
I'd follow what cbeattie mentioned above and let us know!
MPIvan
Re: CentOS errors
Post by MPIvan »
Yup now it is ok ... but i have now new problem ... i create new file in objects named routers.cfg ... and i put one host with service ping to check ... and in the nagios/etc nagios.cfg file i have add the the routers.cfg file and when i try to restart it gave me the status of the configurations like when i run the command /usr/local/nagios/bin/nagio -v /usr/local/nagios/etc/nagios.cfg and when i go to the page on services iv got this error message
Whoops!
Error: Could not read host and service status information!
The most common cause of this error message (especially for new users), is the fact that Nagios is not actually running. If Nagios is indeed not running, this is a normal error message. It simply indicates that the CGIs could not obtain the current status of hosts and services that are being monitored. If you've just installed things, make sure you read the documentation on starting Nagios.
Some other things you should check in order to resolve this error include:
Check the Nagios log file for messages relating to startup or status data errors.
Always verify configuration options using the -v command-line option before starting or restarting Nagios!
Make sure you read the documentation on installing, configuring and running Nagios thoroughly before continuing. If all else fails, try sending a message to one of the mailing lists. More information can be found at http://www.nagios.org.
also i have notes that when i do ls i have dots "." at the end of the permission colon
[root@mpnagios etc]# ls -la
total 76
drwxrwxr-x. 3 nagios nagios 4096 Oct 22 16:52 .
drwxr-xr-x. 8 root root 4096 Oct 22 16:49 ..
-rw-rw-r--. 1 nagios nagios 12015 Oct 22 16:49 cgi.cfg
-rw-r--r--. 1 root root 26 Oct 22 16:52 htpasswd.users
-rw-rw-r--. 1 nagios nagios 44526 Oct 22 18:35 nagios.cfg
drwxrwxr-x. 2 nagios nagios 4096 Oct 22 17:45 objects
-rw-rw----. 1 nagios nagios 1312 Oct 22 16:49 resource.cfg
Re: CentOS errors
The period is related to SELinux ACLs:
http://superuser.com/questions/230559/w ... with-chmod
As for whether or not that is related, I do not know.
MPIvan
Re: CentOS errors
Post by MPIvan »
No still nothing ... any way i think that thats not a problem at all ... because i can modify the nagios.cfg file, for example if i uncomment "#cfg_file=/usr/local/nagios/etc/objects/switch.cfg" it works ... but if i add another file like routers.cfg it wont work ...
sreinhardt
-fno-stack-protector
Re: CentOS errors
Post by sreinhardt »
Where did you put the routers.cfg, and what permissions are presently on it?
IvanAK
Re: CentOS errors
Post by IvanAK »
Sorry i reply with this user ... but im in a hurry ... the routers.cfg files is in /usr/local/nagios/etc/objects ... where the switch cfg is and windows and template and etc.... and the permissions that it has is 664 ( rw-rw-r- and nagios:nagios ) ...
cbeattie
Re: CentOS errors
Post by cbeattie »
What does it say when you run Nagios' configuration check? (Adjust it if your paths are different)
If there's a problem with your configuration files, the config check will print the name of the offending file and the line number in that file. That'll tell us where to look next.
MPIvan
Re: CentOS errors
Post by MPIvan »
No there is no problems im checking before im restarting
Nagios Core 4.0.1
Last Modified: 10-15-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 9 services.
Warning: Host 'RouterCiscoT' has no default contacts or contactgroups defined!
        Checked 2 hosts.
        Checked 2 host groups.
        Checked 0 service groups.
        Checked 1 contacts.
        Checked 1 contact groups.
        Checked 24 commands.
        Checked 5 time periods.
        Checked 0 host escalations.
        Checked 2 hosts
        Checked 0 host dependencies
        Checked 5 timeperiods
Checking misc settings...
Total Warnings: 1
Total Errors:   0
[root@mpnagios objects]#
and here is what iv got when im trying to restart
[root@mpnagios objects]# /etc/init.d/nagios restart
Nagios Core 4.0.1
License: GPL
Checking objects...
        Checked 9 services.
        Checked 2 hosts.
        Checked 1 contacts.
        Checked 2 hosts
Total Warnings: 1
Total Errors:   0
Object precache file created:
/usr/local/nagios/var/objects.precache
Its the same output ...
MPIvan
Re: CentOS errors
Post by MPIvan »
Ok i think i have solution .... in the previous reply and output there was 1 Warning about contact ... when i fix this, everything back to normal. I dont have this problem on Ubuntu or previous version of nagios is this some kind of bug or ??? because it is warning i think should be continue ...
abrist
Red Shirt
Re: CentOS errors
Post by abrist »
Did you change anything else? Config warnings should not cause this issue.
