I removed all host escalation from Nagios and write to config file successfully. However verify config failed with "no host" and "no service error". I tried to add a host "al1cmsch01" and this is what I get at verify config. I'm also attaching the al1cmsch01.cfg file:
Error: Invalid max_check_attempts value for host 'al1cmsch01'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/al1cmsch01.cfg', starting on line 14)
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/al1cmsch01.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
nagiosxi stuck at applying configuration
Re: nagiosxi stuck at applying configuration
Go to the CCM->Hosts, and click on the "al1cmsch01" host to modify it. Click on "Manage Templates", select "xiwizard_generic_host"->Add Selected->Close->Save. Verify your configuration again via the "Write Config Tool". It there are no errors, apply configuration.
I did these and at verify config it says:
I then created a test service, but still get the same no service error:
http://technet.microsoft.com/en-us/libr ... 81005.aspx
Configuration Manager 2007 clients cannot be assigned to secondary sites; they are always assigned to the parent primary site. However, if they reside in the boundaries of the secondary site, they can take advantage of any proxy management points and distribution points at the secondary site.
Error: There are no services defined!
Nagios Core 3.5.0
License: GPL
Checking services...
Checked 0 services.
Checking hosts...
Warning: Host 'al1cmsch01' has no default contacts or contactgroups defined!
Checked 1 hosts.
Checking host groups...
Checked 9 host groups.
Checking service groups...
Checked 3 service groups.
Checking contacts...
Checked 3 contacts.
Checking contact groups...
Checked 2 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 109 commands.
Checking time periods...
Checked 12 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 1
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
Did you remove the localhost checks? If so, please do not do this.
Create a new service check and apply it to a host. Then try to apply configuration again. If it fails, post the output of the verification once again.
Did you delete the localhost and its services? Do you have any services at all? Run the Write Config Tool once again and show the output (CCM->Write Config Files).
Can you elaborate? I am not sure I understand how this is relevant...I then created a test service, but still get the same no service error:
Hi lmiltchev,
sorry I posted the wrong message on that technet link. It basically has the same error message as the first paste.
update: I now after applied abrist's solution as below and now there's no errors in verify config anymore. But still I hang at "Waiting for configuration verification".
I did delete the localhost and its services, and right now I only have a test service. Here is the verify error log:
Nagios Core 3.5.0
License: GPL
Processing object config file '/usr/local/nagios/etc/services/test.cfg'...
Checked 0 services.
Checking hosts...
Checked 1 hosts.
Checked 3 contacts.
Total Warnings: 1
Total Errors: 1
Hi abrist,
I did remove localhost service/host. I created a new service check named test and applied it to al1cmsch01 host, and NO ERRORS NOW:
Nagios Core 3.5.0
License: GPL
Warning: Service 'test' on host 'al1cmsch01' has no default contacts or contactgroups defined!
Checked 1 services.
Checking hosts...
Checked 1 hosts.
Checked 3 contacts.
Total Warnings: 2
Total Errors: 0
Nagios Core 3.5.0
License: GPL
Checked 0 services.
Checking hosts...
Checked 1 hosts.
Checked 3 contacts.
Total Warnings: 1
Total Errors: 1
Hi abrist,
Nagios Core 3.5.0
License: GPL
Checked 1 services.
Checking hosts...
Checked 1 hosts.
Checked 3 contacts.
Total Warnings: 2
Total Errors: 0
Now try applying configuration once again.nanz28v wrote:Things look okay - No serious problems were detected during the pre-flight check
Arhhh, it still hangs at the applying config screen after giving it 15 minutes at least (since I'm working on something concurrent at the time).
Is it successfully applying though? What are you working on along side the apply configuration?
Yes I can write to config file then verify it without issue at all. However if I add a test service then apply the config it still hangs there. I did nothing the whole time while the config application is running. Attached please find the screenshot for the hung screen.
