(No output on stdout) stderr:
deepshikha20
Re: (No output on stdout) stderr:
PFA. Please help to rectify this. My deadline is near.
resource.cfg- resource
- (1.31 KiB) Downloaded 432 times
nagios.cfg- nagios
- (44.74 KiB) Downloaded 449 times
cgi.cfg- cgi
- (12.1 KiB) Downloaded 439 times
Just to clarify because we need to make sure, back on page 1 you posted your windows.cfg and commands.cfg files. In commands.cfg, your check_nt command had "-s password" in it. Did you modify that to hide your password or is that literally what is in the commands.cfg file? I noticed your resource.cfg had commented out the usual password macro, so I wanted to make sure.
deepshikha20
This is the actual one . I have not modified the password.
Could you run this and post the output?
/usr/local/nagios/libexec/check_nt -VBe sure to check out our Knowledgebase for helpful articles and solutions!
deepshikha20
Nothing came when i run that command. PFA.
Thanks.
Regards,
Deepshikha
Thanks.
Regards,
Deepshikha
- Box293
- Too Basu
That looks like your problem, I get:
I suggest you recompile nagios-plugins from source.
Here's a link for doing it on CentOS 6.5:
http://sites.box293.com/nagios/guides/i ... centos-6-5
Or CentOS 7.0:
http://sites.box293.com/nagios/guides/i ... centos-7-0
check_nt v2.0.3 (nagios-plugins 2.0.3)Here's a link for doing it on CentOS 6.5:
Or CentOS 7.0:
