MRTG problems with RRD returning "got: ???/???"
cfgriffith
Re: MRTG problem
Post by cfgriffith »
Hmm so I copied the folder to my home directory. After doing that the server began to slow way down and I eventually hard to hard restart it in Vcenter. Is back up now but still having same issues. Part of me is hesitant to delete said files as they have a lot of graph data built up.
On the bad side it seems like all graphing (Not just bandwidth) broke around 6:19PM Sunday. Do you still think I should delete all files in said folder and will I be able to get graphing data back from the backup files if this doesn't fix the problem?
For the graphs I do see, if I go back to last week I see all the graphing data. Of course most of the objects I have added since then do not actually have any graph at all.
cfgriffith
Re: MRTG problem
Okay so now everything has graphs, but they are still empty.
Also I am seeing this now when I run
sudo env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --debug="snpo,log" --logging $HOME/mrtg_troubleshooting.txt
Looking at one of my switches OID 675:
2015-03-12 15:47:54 -- --log: RRDs::tune(/var/lib/mrtg/10.32.20.1_675.rrd -a ds0:125000000 -a ds1:125000000 -d ds0:COUNTER -d ds1:COUNTER)
2015-03-12 15:47:54 -- --log: RRDs::update(/var/lib/mrtg/10.32.20.1_675.rrd, '1426193269:136572425920084:293123232588921')
2015-03-12 15:47:54 -- --log:  got: ???/???
cfgriffith
Re: MRTG problems with RRD returning "got: ???/???"
FYI, I work with Benson and my post about MRTG is somewhat tied to this problem. I am effectively taking over for him in this regard.
Here is my thread:
http://support.nagios.com/forum/viewtop ... 65#p130065
Here is the requested information:
# Multi Router Traffic Grapher -- Example Configuration File
# This file is for use with mrtg-2.0
# Note:
# * Keywords must start at the begin of a line.
# * Lines which follow a keyword line which do start
# with a blank are appended to the keyword line
# * Empty Lines are ignored
# * Lines starting with a # sign are comments.
# Where should the logfiles, and webpages be created?
# Minimal mrtg.cfg
HtmlDir: /var/www/mrtg
ImageDir: /var/www/mrtg
LogFormat: rrdtool
LogDir: /var/lib/mrtg
ThreshDir: /var/lib/mrtg
WorkDir: /var/lib/mrtg
Include: conf.d/*.cfg
Forks: 4
cmerchant
Post by cmerchant »
I merged the two threads here.
cfgriffith
Brief update. About an hour after aforementioned reboot all the graphs started working again, most of them not having any lost any data during the time the graphs were not working. I will post if it seems to break again. Is there any log I could get to you guys to see what exactly happened and why they work now?
Here are the log files and their locations.
/usr/local/nagios/var/perfdata.log
/usr/local/nagios/var/nagios.log
/usr/local/nagios/var/npcd.log
cfgriffith
Sorry for the long delay for this. Everything for the most part seems to be working now. If I have problems related to this again should I post in this thread or a new one?
I am glad your issue has been resolved! You can start a new thread.
