MRTG problems with RRD returning "got: ???/???"
msbensonstk
After a network downtime last weekend, all of out MRTG poles for network devices are returning:
2015-03-02 10:58:47 -- --log: RRDs::tune(/var/lib/mrtg/10.0.1.1_528.rrd -a ds0:100000000 -a ds1:100000000 -d ds0:COUNTER -d ds1:COUNTER)
2015-03-02 10:58:47 -- --log: RRDs::update(/var/lib/mrtg/10.0.1.1_528.rrd, '1425315526:0:0')
2015-03-02 10:58:47 -- --log: got: ???/???
Resulting in graphs that are flat-lined at "0". In the past we have simply deleted the RRD files and the next pole fixes the counter and we start getting real values back.
However we do not want to lose the historic data in the RRD databases anymore, so we would like a method to fix this issue _without_ removing the database. How would we go about doing this?
Re: MRTG problems with RRD returning "got: ???/???"
Do you see any errors when you run the following command?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgBe sure to check out our Knowledgebase for helpful articles and solutions!
msbensonstk
Nope, no errors are produced when running LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
That log snippet I posed at the top of the thread was produced with:
sudo env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --debug="snpo,log" --logging ~/mrtg_troubleshooting.txt
The log has no erros in it at all:
[@nagiosxi0 ~]$ grep -c -i error ~/mrtg_troubleshooting.txt
0
0
Can you run the following and post the results?
service npcd status
service crond status
tail -50 /usr/local/nagios/var/perfdata.log
ls -la /usr/local/nagios/var/spool
ls /usr/local/nagios/var/spool/xidpe | wc -l
ls /usr/local/nagios/var/spool/perfdata | wc -l
ll /var/lib/mrtg
msbensonstk
[nagios@nagiosxi0 ~]$ service npcd status
NPCD running (pid 5099).
[nagios@nagiosxi0 ~]$ service crond status
crond (pid 4992) is running...
[nagios@nagiosxi0 ~]$ tail -50 /usr/local/nagios/var/perfdata.log
2015-01-29 15:08:57 [13057] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-01-29 15:08:57 [13057] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-01-29 15:08:57 [13057] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-01-29 15:08:57 [13057] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//host-perfdata.1422565725-PID-13057 deleted
2015-01-29 15:08:57 [13057] [0] *** process_perfdata.pl terminated on signal ALRM
2015-01-29 15:35:29 [18217] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-01-29 15:35:29 [18217] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-01-29 15:35:29 [18217] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-01-29 15:35:29 [18217] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//host-perfdata.1422567165-PID-18217 deleted
2015-01-29 15:35:29 [18217] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-04 21:52:07 [24583] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-04 21:52:07 [24583] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-04 21:52:07 [24583] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-04 21:52:07 [24583] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1423108320-PID-24583 deleted
2015-02-04 21:52:07 [24583] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-20 19:15:18 [14944] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-20 19:15:18 [14944] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-20 19:15:18 [14944] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-20 19:15:18 [14944] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1424481299-PID-14944 deleted
2015-02-20 19:15:18 [14944] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-20 19:16:09 [17818] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-20 19:16:09 [17818] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-20 19:16:09 [17818] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-20 19:16:09 [17818] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1424481360-PID-17818 deleted
2015-02-20 19:16:09 [17818] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-24 21:55:33 [11256] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-24 21:55:33 [11256] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-24 21:55:33 [11256] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-24 21:55:33 [11256] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1424836495-PID-11256 deleted
2015-02-24 21:55:33 [11256] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-25 22:36:07 [28462] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-25 22:36:07 [28462] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-25 22:36:07 [28462] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-25 22:36:07 [28462] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//host-perfdata.1424925356-PID-28462 deleted
2015-02-25 22:36:07 [28462] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-25 22:36:07 [28463] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-25 22:36:07 [28463] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-25 22:36:07 [28463] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-25 22:36:07 [28463] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1424925356-PID-28463 deleted
2015-02-25 22:36:07 [28463] [0] *** process_perfdata.pl terminated on signal ALRM
2015-02-26 19:06:28 [1733] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-02-26 19:06:28 [1733] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-02-26 19:06:28 [1733] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-02-26 19:06:28 [1733] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1424999172-PID-1733 deleted
2015-02-26 19:06:28 [1733] [0] *** process_perfdata.pl terminated on signal ALRM
2015-03-02 20:30:24 [19225] [0] *** TIMEOUT: Timeout after 5 Sec. ****
2015-03-02 20:30:24 [19225] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2015-03-02 20:30:24 [19225] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2015-03-02 20:30:24 [19225] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1425349811-PID-19225 deleted
2015-03-02 20:30:24 [19225] [0] *** process_perfdata.pl terminated on signal ALRM
[nagios@nagiosxi0 ~]$ ls -la /usr/local/nagios/var/spool
total 5672
drwxr-xr-x 5 nagios nagios 4096 Feb 23 2012 .
drwxrwxr-x 6 nagios nagios 4096 Mar 3 13:18 ..
drwxrwsr-x 2 nagios nagcmd 36864 Mar 3 12:52 checkresults
drwxr-xr-x 2 nagios nagios 5726208 Mar 3 13:18 perfdata
drwxr-xr-x 2 nagios nagios 4096 Apr 11 2012 xidpe
[nagios@nagiosxi0 ~]$ ls /usr/local/nagios/var/spool/xidpe | wc -l
0
[nagios@nagiosxi0 ~]$ ls /usr/local/nagios/var/spool/perfdata | wc -l
2
[nagios@nagiosxi0 ~]$ ll /var/lib/mrtg
total 68908
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_504.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_505.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_506.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_507.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_508.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_509.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_510.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_511.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:45 10.0.1.1_520.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:45 10.0.1.1_522.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_528.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 10.0.1.1_529.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:45 10.0.1.1_532.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:45 10.0.1.1_533.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:45 10.0.1.1_539.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10106.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10107.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10108.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10109.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10110.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10111.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10112.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10113.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10114.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10115.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10116.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10117.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10118.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10119.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10120.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10121.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10122.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10123.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10124.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10125.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10126.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10127.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_10128.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.29_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10106.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10107.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10108.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10109.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10110.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10111.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10112.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10113.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10114.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10115.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10116.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10117.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10118.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10119.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10120.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10121.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10122.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10123.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10124.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10125.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10126.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10127.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_10128.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.129.30_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.11_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.11_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.11_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.13_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.13_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.13_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.15_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.15_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.15_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.17_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.17_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.17_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.17_4.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.17_5.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.5_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.5_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.5_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.7_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.7_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.7_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.7_4.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.7_5.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.9_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.9_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.9_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.9_4.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.20.9_5.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10106.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10107.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10108.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10109.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10110.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10111.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10112.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10113.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10114.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10115.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10116.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10117.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10118.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10119.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10120.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10121.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10122.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10123.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10124.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10125.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10126.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10127.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10128.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10129.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10130.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10131.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10132.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10133.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10134.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10135.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10136.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10137.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10138.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10139.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10140.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10141.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10142.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10143.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10144.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10145.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10146.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10147.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10148.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10149.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10150.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10151.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_10152.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_20.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.171_5010.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_100.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_106.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_107.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_108.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_109.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_10.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_110.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_111.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_112.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_113.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_114.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_115.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_116.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_117.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_118.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_119.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_11.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_120.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_126.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_128.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_129.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_12.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_130.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_131.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_132.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_133.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_134.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_136.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_137.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_138.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_139.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_13.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_140.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_141.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_142.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_143.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_144.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_145.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_146.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_147.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_148.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_149.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_14.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_150.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_151.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_152.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_153.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_154.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_155.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_156.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_157.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_158.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_159.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_15.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_160.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_16.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_17.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_18.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_19.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_1.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_20.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_21.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_22.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_23.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_24.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_25.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_26.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_27.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:57 140.225.22.3_288.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_28.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_291.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_29.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_300.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:55 140.225.22.3_301.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_30.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_310.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_31.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_32.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_33.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_34.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_35.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_36.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_37.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_38.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_39.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_40.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_41.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_42.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_43.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_44.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_45.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_46.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_47.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_48.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_49.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_4.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_50.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_51.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_52.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_53.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_54.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_55.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_56.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_57.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_58.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_59.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_5.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_60.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_61.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_62.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_63.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_64.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_65.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_66.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_67.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_68.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_69.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_6.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_70.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_71.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_72.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_73.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_74.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_75.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_76.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_77.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_78.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_79.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_7.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_80.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_81.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_82.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_83.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_84.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_85.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_86.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_87.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_88.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_89.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_8.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_90.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_91.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_92.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_93.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_94.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_95.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_96.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_97.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_98.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_99.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.3_9.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_10.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_111.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_112.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_11.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_12.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_13.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_14.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_15.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_16.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_17.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_18.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_19.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_20.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_21.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_22.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_23.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_24.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_25.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_26.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_27.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_28.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_29.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_30.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_31.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_32.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_33.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_34.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_35.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_36.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_37.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_38.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_39.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_40.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_41.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_42.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_43.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_44.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_45.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_46.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_47.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_48.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_49.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_4.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_50.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_51.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_5.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_6.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_7.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_8.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.4_9.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_100.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_106.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_107.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_108.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_109.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_10.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_110.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_111.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_112.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_113.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_114.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_115.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_116.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_117.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_11.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_125.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_126.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_127.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_128.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_129.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_12.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:50 140.225.22.5_130.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_13.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_14.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_15.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_16.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_17.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_18.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_19.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_20.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_21.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_22.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_23.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_24.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_25.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_26.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_27.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_28.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_29.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_2.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_30.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_31.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_32.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_33.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_34.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_35.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_36.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_37.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_38.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_39.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_3.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_40.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_41.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_42.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_43.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_44.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_45.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_46.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_47.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_48.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_49.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_4.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_50.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_51.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_52.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_53.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_54.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_55.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_56.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_57.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_58.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_59.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_5.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_60.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_61.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_62.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_63.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_64.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_65.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_66.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_67.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_68.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_69.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_6.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_70.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_71.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_72.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_73.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_74.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_75.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_76.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_77.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_78.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_79.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_7.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_80.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_81.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_82.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_83.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_84.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_85.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_86.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_87.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_88.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_89.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_8.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_90.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_91.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_92.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_93.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_94.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_95.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_96.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_97.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_98.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_99.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.5_9.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10121.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10122.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10123.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_10124.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_5001.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_5179.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.6_608.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10101.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10102.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10103.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10104.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10105.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10121.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10122.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10123.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_10124.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_5001.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.22.7_5179.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_1107705856.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_1107788385.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_34129154.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_34391298.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_34653442.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_34915586.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_35177730.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_35439874.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_35702018.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_35964162.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_36226306.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_36488450.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_36750594.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_37012738.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_37274882.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_37537026.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_37799170.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_38061314.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_38323458.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_38585602.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_38847746.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_39109890.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_39372034.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_39634178.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_39896322.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_40158466.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_40420610.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_40682754.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_40944898.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_41207042.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_41469186.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_41731330.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_41993474.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_42255618.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_42517762.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_42779906.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_43042050.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_43304194.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_43566338.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_43828482.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_44090626.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_44352770.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_44614914.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_44877058.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_45139202.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_45401346.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_45663490.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_45925634.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_46187778.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_46449922.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.195_47252738.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_1107705856.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_1107788385.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_34129154.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_34391298.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_34653442.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_34915586.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_35177730.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_35439874.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_35702018.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_35964162.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_36226306.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_36488450.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_36750594.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_37012738.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_37274882.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_37537026.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_37799170.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_38061314.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_38323458.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_38585602.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_38847746.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_39109890.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_39372034.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_39634178.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_39896322.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_40158466.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_40420610.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_40682754.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_40944898.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_41207042.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_41469186.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_41731330.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_41993474.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_42255618.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_42517762.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_42779906.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_43042050.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_43304194.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_43566338.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_43828482.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_44090626.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_44352770.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_44614914.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_44877058.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_45139202.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_45401346.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_45663490.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_45925634.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_46187778.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_46449922.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_47252738.rrd
-rw-r--r-- 1 root root 105312 Mar 3 13:15 140.225.23.196_47514882.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10003.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10004.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10005.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10006.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10007.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10008.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10009.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10010.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10011.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10012.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10013.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10014.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10015.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10016.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10017.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10018.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10019.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10020.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10021.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10022.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10023.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10024.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10101.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_10102.rrd
-rw-r--r-- 1 root root 105312 Mar 2 10:25 140.225.23.49_20.rrd
-rw-r--r-- 1 root root 0 Mar 3 13:15 mrtg.ok
Could you edit this file
/usr/local/nagios/etc/pnp/process_perfdata.cfg
Change
to
Save the changes and run the following
service npcd restart
Wait about 15 minutes and let us know if the graphs start to populate.
Change
TIMEOUT = 5Code: Select all
TIMEOUT = 20service npcd restart
msbensonstk
No change after setting TIMEOUT = 20, restarting npcd, and waiting 15mn. Still getting ???/??? in the debug output from MRTG
This is going to be big but could you run the following and upload the rrdump.txt file?
rrdtool dump /var/lib/mrtg/10.0.1.1_528.rrd > rrddump.txtBe sure to check out our Knowledgebase for helpful articles and solutions!
msbensonstk
rrddump.txt attached
EDIT: I just realized the RRD file you asked for was from an interface with no traffic on it, so it wouldn't be very helpful. I gave you 10.0.1.1_506 this time which actually has data in it.
That dump file doesn't have any data before yesterday so it can't be rebuilt.
Go to the home screen, select "Service Detail" and select an interface that was up last week. Click on the Performance Graphs tab and change the timeframe to 7 days.
Do you see data from last week?
