Nagios Graph error
Re: Nagios Graph error
No change after above changes
jdalrymple
- Skynet Drone
Please post the output of the updated plugin so that we can see what the problem may be.
After modification
--login)
loginchk=`sqlplus dummy/user@$2 < /dev/null`
loginchk2=` echo $loginchk | grep -c ORA-01017`
loginchk3=` echo "$loginchk" | grep "ORA-" | head -1`
if [ ${loginchk2} -eq 1 ] ; then
echo "OK - dummy login connected|'Number of Widgets'=$metricwidgets;$warning;$critical;;"
exit $STATE_OK
else
exit $STATE_CRITICAL
fi
[root@db1 libexec]# ./check_oracle --login db1
OK - dummy login connected|'Number of Widgets'=;;;;
[root@db1 libexec]#
--login)
exit $STATE_OK
else
fi
[root@db1 libexec]#
Can you upload the whole plugin? I want to run this on my system and tweak it a bit. Something isn't right and it's hard to tell what from just snippets.
Please find the attachment
check_oracle.txt- (8.86 KiB) Downloaded 636 times
jdalrymple
- Skynet Drone
I'm being horribly repetitive and for that I'm sorry. The problem is your code "looks" OK, but it's obviously not working. The problem is we cannot test/debug it because we don't have the Oracle environment set up to do such a thing.
Going back to the fundamentals:
Also, get rid of your 's and make it 1 word: number_of_widgets
You have to get a number after that equal sign. That is up to you to get your code working in such a way that the scalar ends up there. The fact that it's not showing up simply means your custom plugin isn't working, it has nothing to do with Nagios.nareshtis wrote:[root@db1 libexec]# ./check_oracle --login db1
I dont see any difference after the changes
OK - dummy login connected|'Number_of_Widgets'=;;;;
jdalrymple
- Skynet Drone
I need to impress upon you that this is not something we can fix. I can offer pointers and such, but at the end of the day it's on you to make sure that perfdata is populated. If there is no numeric value output in the perfdata then Nagios has nothing to graph. I'll do my best... here is your (relevant) code:
Here is the output you shared:
Lastly - what performance do you want to graph? This portion of the plugin appears to only check whether a login is possible or not. Graphing requires some metric to be placed on a chart. I'm totally confused about how you plan to graph "the quantity of" "dummy login connected" over time???
--login)
echo "OK - dummy login connected"
exit $STATE_OK
else
echo "CRITICAL - $loginchk3|Number of Widgets=$metricwidgets;$warning;$critical;;"
fi
;;I can't make any sense of how you're getting the output you're getting. If the check returns OK then you should never make it into the logic where you've put in performance data. In addition - you used the variables exactly as I wrote them. I was creating an ambiguous sample to try to help you understand the basic layout of performance data, there was no intent for you to use those variables explicitly as they don't exist anywhere else in your code.nareshtis wrote:[root@db1 libexec]# ./check_oracle --login db1
