Configure Exim MailServer Logs With NLS
Re: Configure Exim MailServer Logs With NLS
Hm, java can't start and this may be the issue. What is the result of top|head -5 and free -m?
rlinux57
Post by rlinux57 »
[root@logs ~]# top|head -5
top - 22:45:47 up 15 days,  6:07,  1 user,  load average: 0.01, 0.02, 0.00
Tasks:  37 total,   1 running,  36 sleeping,   0 stopped,   0 zombie
Cpu(s):  0.2%us,  0.1%sy,  0.0%ni, 99.7%id,  0.1%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:   2097152k total,  1716980k used,   380172k free,        0k buffers
Swap:        0k total,        0k used,        0k free,    57808k cached
[root@logs ~]# free -m
             total       used       free     shared    buffers     cached
Mem:          2048       1676        371          3          0         56
-/+ buffers/cache:       1619        428
Swap:            0          0          0
jolson
Attack Rabbit
Post by jolson »
Could not reserve enough space for object heap
This is the concerning error to me, and it's why we checked your available memory. Is there any chance you could bump the server up to 4GB of memory temporarily to see if that helps resolve the issue?
Logstash will want at least 256MB of RAM to start up properly, and java appears to be unable to allocate any memory to itself. Let me know if the above helps, thanks!
Twits Blog
rlinux57
Post by rlinux57 »
I have upgraded the ram 2GB to 4GB, its working but after a couple of second service again dead.
service logstash restart
Restarting Logstash Daemon:                                [  OK  ]
WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
                                                           [  OK  ]
[root@logs ~]# service logstash status
Logstash Daemon dead but pid file exists
rlinux57
Post by rlinux57 »
Now i have upgraded ram upto 8GB but after sometime service got stuck.
[root@logs ~]# service logstash start
Starting Logstash Daemon: WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
                                                           [  OK  ]
Logstash Daemon (pid  3894) is running...
What is the result of a top|head -5 now?
Also, please post the output for this too. grep -i 'out of memory' /var/log/messages
rlinux57
Post by rlinux57 »
root@logs ~]# top | head -5
top - 12:37:38 up 22:32,  1 user,  load average: 0.01, 0.05, 0.09
Tasks:  39 total,   1 running,  38 sleeping,   0 stopped,   0 zombie
Mem:   8290304k total,  1132944k used,  7157360k free,        0k buffers
Swap:        0k total,        0k used,        0k free,    67008k cached
[root@logs ~]# grep -i 'out of memory' /var/log/messages
Feb  9 14:03:46 logs kernel: [1975726.697697] Out of memory in UB 147: OOM killed process 618 (java) score 0 vm:4718000kB, rss:2615528kB, swap:0kB
Can you verify a few things?
- A screenshot of your Backup & Maintenance page.
- A screenshot of your Index Status page.
It looks like your memory is getting consumed over time, so I have a feeling the retention is storing too much data to cache (on your ram), and then causing NLS to crash.
rlinux57
Post by rlinux57 »
How can i provide this information please let me know.
hsmith
Agent Smith
Post by hsmith »
You take a screenshot, and can attach it here using either the tags or the 'Upload attachment' button on the bottom of the screen when writing a new post.
Former Nagios Employee.
me.
