Posts: 9191 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Wed Jun 15, 2016 4:56 pm
Can you post your nsclient.ini file after the reinstall?
Can you try putting a blank password in the ini file and see that works?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Wed Jun 15, 2016 5:03 pm
What happens when you stop the service on the Windows server? Does it still report invalid password?
Do you have a file in the NSClient++ directory called boot or boot.ini ? If yes, what are the contents.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
donKanon
Posts: 18 Joined: Wed Jun 08, 2016 4:38 pm
Post
by donKanon » Thu Jun 16, 2016 12:57 am
tgriep wrote: Can you post your nsclient.ini file after the reinstall?
I leave that just like for default
;password=
donKanon
Post
by donKanon » Thu Jun 16, 2016 1:01 am
Box293 wrote: What happens when you stop the service on the Windows server? Does it still report invalid password?
the report show a grey status.
the NSCLIENT++ have a boot.ini this is:
[settings]
1=ini://${exe-path}/nsclient.ini
[main]
write=ini://${exe-path}/nsclient.ini
that I metioned that we have a older nagios version full operational with the same configuration and all the server are reporting properly.
Post
by Box293 » Thu Jun 16, 2016 1:27 am
donKanon wrote: tgriep wrote: Can you post your nsclient.ini file after the reinstall?
;password=
He's asking you to uncomment it (remove the ; at the start) to see if that helps.
Can you post your nsclient.ini file.
donKanon wrote: Box293 wrote: What happens when you stop the service on the Windows server? Does it still report invalid password?
What output / error message is produced ?
Privacy Policy .
donKanon
Post
by donKanon » Thu Jun 16, 2016 10:40 am
the result I show it below and Attach the nsclient.ini with the password =
nsclient.ini
(1.04 KiB) Downloaded 264 times
Post
by Box293 » Thu Jun 16, 2016 4:33 pm
I just tried your config file and it works correctly, no password error.
First thing I would do is restart the server that NSClient++ is running on.
Can you double check that 10.30.1.80 is the IP address of the machine that you provided the nsclient.ini file from.
Privacy Policy .
donKanon
Post
by donKanon » Mon Jun 20, 2016 8:52 am
yes it's the IP... and of course I restart de service many times..
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Mon Jun 20, 2016 10:28 am
Did you restart the entire machine, or just the service?
If this is working fine on another machine, can you show us the full input / output and check_command definitions it's using?
Can you show us what you mean by a 'grey' status? What is the error message?
