Nagioxi CPU consumption strongly increased
Re: Nagioxi CPU consumption strongly increased
I asked for more input from you in the ticket, let me know if you received it or not.
Frédéric GRANAT
Profile of the 5.2.3
Reason: Removed the profile
Can you edit the /etc/php.ini file and remove the following line from the bottom of the file?
Then restart the Apache process by running
Let us know how it works out.
extension=ixed.5.2.linCode: Select all
service httpd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
avandemore
There are a large amount of timeout's in the logs. Do you know why this is? Too many timeouts can cause bottlenecks.
Previous Nagios employee
