check_mrtgtraf
Re: check_mrtgtraf
You had some typo's when you ran the command last time. Can you run it again?
Before posting the mrtg.txt file, take a look at is and see if it is valid and if there are any clues on why it is not running on your system.
jmac727
Re: check_mrtgtraf
Post by jmac727 »
I apologize for that. Here is the corrected version.
mrtg (2).txt
(1.14 KiB) Downloaded 366 times
Re: check_mrtgtraf
I have attached 2 config files to this post.
Download them and the one called mrtg.cfg, overwrite your /etc/mrtg/mrtg.cfg file with the one from the post.
Then, lets clear out and configuration files by running the following as root.
rm /etc/mrtg/conf.d/*
The attachment called, 192.168..2.126.cfg put is in the following folder.
/etc/mrtg/conf.d
See if that fixes the issue.
192.168.2.126.cfg
(60.66 KiB) Downloaded 366 times
mrtg.cfg
(751 Bytes) Downloaded 363 times
jmac727
Re: check_mrtgtraf
Post by jmac727 »
No dice. I ran the debug line again and attached the resulting .txt files.
mrtg.txt
(129.64 KiB) Downloaded 336 times
Re: check_mrtgtraf
This error from the file needs to be resolved.
ERROR: could not find rrdtool. Use PathAdd: in mrtg.cfg to help mrtg find rrdtool
You need to install the following packages on your server as MRTG needs them to create the rrd files.
rrdtool
rrdtool-perl
jmac727
Re: check_mrtgtraf
Post by jmac727 »
I did
sudo apt install rrdtool
Do I need to do anything for the rrdtool-perl?
jmac727
Re: check_mrtgtraf
Post by jmac727 »
Newest .txt doc
mrtg.txt
(129.64 KiB) Downloaded 324 times
Re: check_mrtgtraf
The ubuntu package is called so run the following to install it
apt install mrtg-rrd
jmac727
Re: check_mrtgtraf
Post by jmac727 »
Ok. I ran that. Restarted the whole machine and reran the debug and it comes back with no error in the .txt file. Still nothing.
Re: check_mrtgtraf
Lets recreate the config file for your router.
Run the following command to recreate it but make sure you update any of the settings.
/usr/bin/cfgmaker --show-op-down --noreversedns --zero-speed 100000000 [email protected]:161::::2 >/etc/mrtg/conf.d/192.168.2.126.cfg
