Nagios Fusion Hostgroup Dashboard
This support forum board is for questions relating to Nagios Fusion.
Re: Nagios Fusion Hostgroup Dashboard
If you create a ticket, and include the link to this post, we can schedule a remote session with you to resolve the issue.
To create a ticket, you can use the following link.
https://support.nagios.com/tickets/
This URL is a guide on what is needed to create a ticket.
https://support.nagios.com/kb/article/c ... r-769.html
scharft
Post by scharft »
Hi, as recommend in our remote session, I installed a new linux host with fusion.
The installation and configuration including add the nagios xi instances were successful but 2 instances don't show any information.
Please see attachmend, XISummary.
I have re-added the instances, changed the polling intervall. etc.. but nothing helped.
Any recommendations?
Best Regards
Can you run the following as root on the Fusion server and post the /tmp/varlog.tgz file?
tar cvfz /tmp/varlog.tgz /usr/local/nagiosfusion/var/log/*.log
scharft
Post by scharft »
the varlog is attached.
best Regards
Thanks for the log files.
Can you run the following command as root to get the server ID for the Vienna server and the Bannockburn servers and post it here?
In the log files, I am seeing authentication issues for servers 1, 3 and 6 so can you verify that the user account you are using to poll the server is valid as well as the Fusekey?
To verify that the Fusekey from the Nagios XI servers are correct, run the following on the Fusion server replacing the nagiosxiserver with the XI server's host name and the xxxxxxxxxxxxxxxxxxxxxxxx with the fusion key from the XI server.
curl -XGET https://nagiosxiserver/nagiosxi/api/v1/system/status?fusekey=xxxxxxxxxxxxxxxxxxxxxxxx -k -v
It should come back with the server status information if it is valid.
scharft
Post by scharft »
curl -XGET http://atvinag003.corp.inbaxalta.com/na ... 8BEDFC2E41 -k -v
* About to connect() to atvinag003.corp.inbaxalta.com port 80 (#0)
* Trying 10.110.13.84...
* Connected to atvinag003.corp.inbaxalta.com (10.110.13.84) port 80 (#0)
> GET /nagiosxi/api/v1/system/status?fusekey=60019E5E30DAC56E1CA5CD8BEDFC2E41 HTTP/1.1
> User-Agent: curl/7.29.0
> Host: atvinag003.corp.inbaxalta.com
> Accept: */*
< HTTP/1.1 200 OK
< Date: Thu, 19 Apr 2018 07:00:07 GMT
< Server: Apache/2.2.15 (Red Hat)
< X-Powered-By: PHP/5.3.3
< Access-Control-Allow-Orgin: *
< Access-Control-Allow-Methods: *
< Content-Length: 840
< Connection: close
< Content-Type: application/json
{"instance_id":"1","instance_name":"localhost","status_update_time":"2018-04-19 09:00:01","program_start_time":"2018-04-18 22:15:05","program_run_time":"38702","program_end_time":"0000-00-00 00:00:00","is_currently_running":"1","process_id":"37668","daemon_mode":"1","last_command_check":"1970-01-01 01:00:00","last_log_rotation":"2018-04-18 23:59:59","notifications_enabled":"1","active_service_checks_enabled":"1","passive_service_checks_enabled":"1","active_host_checks_enabled":"1","passive_host_checks_enabled":"1","event_handlers_enabled":"1","flap_detection_enabled":"1","process_performance_data":"1","obsess_over_hosts":"1","obsess_over_services":"1","modified_host_attributes":"129","modified_service_attributes":"133","global_host_event_handler":"xi_host_event_handler","global_service_event_handler":"xi_service_event_handler"}
curl -XGET http://usbbnag1001.corp.inbaxalta.com/n ... 410B79CC15 -k -v
* About to connect() to usbbnag1001.corp.inbaxalta.com port 80 (#0)
* Trying 10.150.76.108...
* Connected to usbbnag1001.corp.inbaxalta.com (10.150.76.108) port 80 (#0)
> GET /nagiosxi/api/v1/system/status?fusekey=330B0011A613913AB0FBDB410B79CC15 HTTP/1.1
> Host: usbbnag1001.corp.inbaxalta.com
> Accept: */*
< HTTP/1.1 200 OK
< Date: Thu, 19 Apr 2018 07:01:35 GMT
< Server: Apache/2.4.6 (Red Hat Enterprise Linux) OpenSSL/1.0.2k-fips PHP/5.4.16
< X-Powered-By: PHP/5.4.16
< Content-Length: 836
{"instance_id":"1","instance_name":"localhost","status_update_time":"2018-04-19 00:01:32","program_start_time":"2018-04-18 20:00:04","program_run_time":"14491","program_end_time":"0000-00-00 00:00:00","is_currently_running":"1","process_id":"17623","daemon_mode":"1","last_command_check":"1969-12-31 16:00:00","last_log_rotation":"2018-04-18 23:59:59","notifications_enabled":"1","active_service_checks_enabled":"1","passive_service_checks_enabled":"1","active_host_checks_enabled":"1","passive_host_checks_enabled":"1","event_handlers_enabled":"1","flap_detection_enabled":"1","process_performance_data":"1","obsess_over_hosts":"0","obsess_over_services":"0","modified_host_attributes":"1","modified_service_attributes":"1","global_host_event_handler":"xi_host_event_handler","global_service_event_handler":"xi_service_event_handler"}
* Connection #0 to host usbbnag1001.corp.inbaxalta.com left intact
I missed adding the command to my last post, can you run the following and add the /tmp/info.txt file to the ticket?
echo 'select * from servers;' |mysql -t -u fusion -pfusion fusion >/tmp/info.txt
Thanks for running the other commands and providing the output.
The Fusekeys are working.
scharft
Post by scharft »
file is attached
best Regards
Reason: Removed attachment and shared with other techs.
Thanks for the file.
It looks like the URL for the Vienna server is missing the .corp for the domain name.
Your example URL from last Thursday does not match the settings in Fusion. Update that and see if that server starts to check in.
The Bannockburn server settings look OK to me but verify them for sure.
If updating the settings for the Vienna server doesn't work, lets run a tcpdump on the Fusion server to capture the data between the servers.
First, you may need to install tcpdump by running the following as root.
yum install tcpdump -y
Then, run the following as root on the fusion server for at least 20 minutes replacing yyyyyyyyy with the name of the server you are testing and xxx.xxx.xxx.xxx with it's IP address.
tcpdump -i any -s 65535 -w yyyyyyyyy.cap dst xxx.xxx.xxx.xxx
Run the command against the Vienna server and or the Bannockburn server is they are still not getting polled data in the Fusion interface.
scharft
Post by scharft »
Hi, attached is the tump, please change the extension from txt to .cap.
best Thomas
