Error code: 9.
habuhejleh
Re: Error code: 9.
Post by habuhejleh »
Dear ,
I want to block all IP's toward our Nagios XI server except Nagios Organization. Please provide me with list of IP's of Nagios company so I allow them only.
habuhejleh
Re: Error code: 9.
Also I uninstalled then installed the Nagios XI and now version 5.5.1 is running but it is slow in GUI considerably.
I tried freeing up the root partition but no luck problem still the same.
Please also find in the attached the error I encounter in the GUI
Re: Error code: 9.
habuhejleh wrote:Dear ,
Your server will only connect to api.nagios.com and assets.nagios.com from the nagios server.
habuhejleh wrote:Also I uninstalled then installed the Nagios XI and now version 5.5.1 is running but it is slow in GUI considerably.
Please send in a profile.zip from Admin -> System Profile for a tech to take a look at this screen certainly doesn't look healthy.
If you ran out of disk space you may have several errors to clean up even after to get back to normal
habuhejleh
Re: Error code: 9.
Here is the profile.zip file
Please specify how to clean up the disk from errors and advise your feedback about the profile.zip.
Re: Error code: 9.
your system is executing ./mnprocd 224 times which is eating all of your CPU
What is this?
habuhejleh
Re: Error code: 9.
I have no any idea about it.
What do you advise to do?
Re: Error code: 9.
I would search the filesystem and find it
locate mnprocd
Also, it appears your nagios user is executing it, you can try funding it here
grep mnprocd -R /usr/local/nagios/etc/
habuhejleh
Re: Error code: 9.
The commands returns empty results:
[root@um-isp-nagios-redline ~]# locate mnprocd
[root@um-isp-nagios-redline ~]# grep mnprocd -R /usr/local/nagios/etc/
[root@um-isp-nagios-redline ~]# su nagios
[nagios@um-isp-nagios-redline root]$ locate mnprocd
[nagios@um-isp-nagios-redline root]$ grep mnprocd -R /usr/local/nagios/etc/
Please advise.
Re: Error code: 9.
run
killall -9 mnprocd
Re: Error code: 9.
Actually I also see this which makes me think there is something you probably do not want running on this server
toranon  11716     1  0 Jul22 ?        00:02:33 /usr/bin/tor --defaults-torrc /usr/share/tor/defaults-torrc -f /etc/tor/torrc
root     11732     1 53 Jul22 ?        15:40:07 ./mnprocd
nagios   11746     1  0 Jul22 ?        00:00:01 socat TCP4-LISTEN:19149,bind=127.0.0.1,fork SOCKS4A:localhost:4kl6x77wi6bgl2vd.onion:27359,socksport=9050
nagios   11910     1  0 Jul22 ?        00:00:01 socat TCP4-LISTEN:19149,bind=127.0.0.1,fork SOCKS4A:localhost:4kl6x77wi6bgl2vd.onion:27359,socksport=9050
nagios   11911     1  0 Jul22 ?        00:00:01 socat TCP4-LISTEN:19149,bind=127.0.0.1,fork SOCKS4A:localhost:4kl6x77wi6bgl2vd.onion:27359,socksport=9050
I would highly recommend rebooting the server and investigating the tor processes
