Check_VMWARE_API Plugin not working
kwhogster
Re: Check_VMWARE_API Plugin not working
Post by kwhogster »
Is this the same version of ESXi/VSphere server as the rest of them (that are working)? Yes all but one I have 9 ESXI hosts 8 6.5 1 6.0
This is an ESXI 6.5 Host having the issue all other hosts work great.
Are the permissions of the user the same? Yes same userid Root and same password I logon to each host or thru vCenter.
Do any other checks work? Yes on the same host I do CPU hardware Check IO check Memory Check network check runtime check service check they all are reporting fine
Do you see the datastores when you log in the server with the same credentials? Yes
Try running:
Will post later but last night when I tried I received no response from any command line on this host had to control break each try
Whenever you are ready.
Can you also run the commands below, and post the output?
dpkg -l | grep libwww-perl
cpan -a | grep libwww-perl
kwhogster
Post by kwhogster »
root@tgcs017:~# dpkg -l | grep libwww-perl
ii libwww-perl 6.15-1 all simple and consistent interface to the world-wide web
root@tgcs017:~# cpan -a | grep libwww-perl
LWP 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Authen::Basic undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Authen::Digest undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Authen::Ntlm 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::ConnCache 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Debug undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::DebugFile undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::MemberMixin undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::cpan undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::data undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::file undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::ftp undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::gopher undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::http undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::loopback undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::mailto undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::nntp undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Protocol::nogo undef 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::RobotUA 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::Simple 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
LWP::UserAgent 6.15 6.38 OALDERS/libwww-perl-6.38.tar.gz
root@tgcs017:~#
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##xxxxxxxxx" -l mem
CHECK_VMWARE_API.PL UNKNOWN - plugin timed out (timeout 30s)
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##xxxxxxxxxxx" -l cpu
CHECK_VMWARE_API.PL OK - cpu usage=298.00 MHz (6.23%) | cpu_usagemhz=298.00;; cpu_usage=6.23%;;
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "############" -l runtime
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##xxxxxxxx" -l vmfs
See image showing all esxi hosts working except for this one
showing all others
showing all others
Any ideas?
It seems like the cpu check is working but the mem, runtime, and vmfs are all timing out... Can you verify that you are using the same credentials?
Can you also upload the plugin that you are using on the forum? Since you modified it a few times, we would like to view it, and compare it to the one that we are using in-house. Thanks!
kwhogster
Post by kwhogster »
Sorry for the delay been sick lately.
Here it is
check_vmware_api.pl
check_vmware_api.pl
(166.42 KiB) Downloaded 846 times
FYI.
It did start working on Saturday but is back again today with same error
Thanks again
npolovenko
Post by npolovenko »
@kwhogster, Please run these commands and show us the output:
/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "############" -l runtime -t 200
/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##xxxxxxxx" -l vmfs -t 200
kwhogster
Post by kwhogster »
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##########" -l runtime -t 200
Use of uninitialized value $subcommand in string ne at ./check_vmware_api.pl line 1899.
CHECK_VMWARE_API.PL OK - 4/15 VMs up, overall status=green, connection state=connected, maintenance=no, 35 health issue(s), no config issues | vmcount=4units;; health_issues=35;; config_issues=0;;
root@tgcs017:/usr/local/nagios/libexec# ./check_vmware_api.pl -H TGCSESXI-1 -u root -p "##########" -l vmfs -t 200
CHECK_VMWARE_API.PL CRITICAL - SOAP request error - possibly a protocol issue: S SL read timeout: at /usr/share/perl5/Net/HTTP/Methods.pm line 278.
at /usr/lib/x86_64-linux-gnu/perl5/5.22/Net/SSL.pm line 191.
Net::SSL::die_with_error(LWP::Protocol::https::Socket=GLOB(0x3c9e4f8), " SSL read timeout") called at /usr/lib/x86_64-linux-gnu/perl5/5.22/Net/SSL.pm lin e 198
Net::SSL::__ANON__("ALRM") called at /usr/lib/x86_64-linux-gnu/perl5/5.2 2/Net/SSL.pm line 202
eval {...} called at /usr/lib/x86_64-linux-gnu/perl5/5.22/Net/SSL.pm lin e 202
Net::SSL::read(LWP::Protocol::https::Socket=GLOB(0x3c9e4f8), "HTTP/1.1 2 00 OK\x{d}\x{a}Date: Tue, 9 Apr 2019 23:04:39 GMT\x{d}\x{a}Cache-Co"..., 1024, 2 048) called at /usr/share/perl5/Net/HTTP/Methods.pm line 278
Net::HTTP::Methods::my_readline(LWP::Protocol::https::Socket=GLOB(0x3c9e 4f8), "Status") called at /usr/share/perl5/Net/HTTP/Methods.pm line 397
Net::HTTP::Methods::read_response_headers(LWP::Protocol::https::Socket=G LOB(0x3c9e4f8), "laxed", 1, "junk_out", ARRAY(0x2e983f8)) called at /usr/share/p erl5/LWP/Protocol/http.pm line 426
LWP::Protocol::http::request(LWP::Protocol::https=HASH(0x3d415e0), HTTP: :Request=HASH(0x3d289e8), undef, undef, undef, 180) called at /usr/share/perl5/L WP/UserAgent.pm line 192
eval {...} called at /usr/share/perl5/LWP/UserAgent.pm line 191
LWP::UserAgent::send_request(LWP::UserAgent=HASH(0x3c913c0), HTTP::Reque st=HASH(0x3d289e8), undef, undef) called at /usr/share/perl5/LWP/UserAgent.pm li ne 274
LWP::UserAgent::simple_request(LWP::UserAgent=HASH(0x3c913c0), HTTP::Req uest=HASH(0x3d289e8), undef, undef) called at /usr/share/perl5/LWP/UserAgent.pm line 282
LWP::UserAgent::request(LWP::UserAgent=HASH(0x3c913c0), HTTP::Request=HA SH(0x3d289e8)) called at /usr/share/perl/5.22/VMware/VICommon.pm line 2398
SoapClient::request(SoapClient=HASH(0x3c9dfd0), "RetrieveProperties", "< _this type=\"PropertyCollector\">ha-property-collector</_this>"..., "\"urn:vim25 /6.5\"") called at (eval 43) line 8275
VimService::RetrieveProperties(VimService=HASH(0x2e2f718), "_this", Mana gedObjectReference=HASH(0x3ca8ab8), "specSet", PropertyFilterSpec=HASH(0x3d27568 )) called at /usr/share/perl/5.22/VMware/VICommon.pm line 1862
ViewBase::update_view_data(Datastore=HASH(0x2cbc6a8), ARRAY(0x27be538)) called at /usr/share/perl/5.22/VMware/VICommon.pm line 1705
Vim::get_view("mo_ref", ManagedObjectReference=HASH(0x3d338a0), "propert ies", ARRAY(0x27be538)) called at ./check_vmware_api.pl line 1211
CheckVMwareAPI::datastore_volumes_info(ARRAY(0x3d33af8), Nagios::Monitor ing::Plugin=HASH(0x2316b10), undef, undef, undef, undef) called at ./check_vmwar e_api.pl line 1885
CheckVMwareAPI::host_list_vm_volumes_info(undef, Nagios::Monitoring::Plu gin=HASH(0x2316b10), undef, undef, undef, undef) called at ./check_vmware_api.pl line 698
eval {...} called at ./check_vmware_api.pl line 580
CheckVMwareAPI::main() called at ./check_vmware_api.pl line 827
at /usr/lib/x86_64-linux-gnu/perl5/5.22/Net/SSL.pm line 202.
ssax
Dreams In Code
Post by ssax »
I see this here:
https://communities.vmware.com/thread/501356
What version are you running?
[root@xid xicore]# perl -MLWP -e 'print "$LWP::VERSION\n"';
6.05
What version of the SDK do you have installed now?
/usr/bin/vmware-cmd --version
Thank you!
kwhogster
Post by kwhogster »
root@tgcs017:/usr/local/nagios/libexec# perl -MLWP -e 'print "$LWP::VERSION\n"';
6.15
root@tgcs017:/usr/bin# vmware-cmd --version
vSphere SDK for Perl version: 6.5.0
Script 'vmware-cmd' version: 6.5.0
ssax
Dreams In Code
Post by ssax »
Send the output of this command:
apt list --installed | grep -i perl
Then try running this command:
cpan -i GAAS/libwww-perl-6.05.tar.gz
Then once it's done installing, test the command again and see if it works. If it doesn't work, try running this command:
cpan -i GAAS/libwww-perl-5.837.tar.gz
Then test again, if it still doesn't work, let us know.
