Services issues
jdalrymple
Skynet Drone
Re: Services issues
Post by jdalrymple »
I feel like the issue is getting confused and perhaps the solution is simpler than we're making it out to be. Is the problem still simply that your script returns UNKNOWN when there is a network or snmp timeout and you wish for it to return CRITICAL? If so that's as simple as changing this code block
if [ ! "$rdatestring" ] ; then
  echo "Time difference could not be calculated; no time received."
  exit 3
fi
to this:
  exit 2
fi
If that's not the desired goal, what is?
imran_khan
Re: Services issues
Post by imran_khan »
We have observed that, services of all the servers are going in “UNKNOWN” section instead of “CRITICAL” when server go down.
It should show in “CRITICAL” section not in “UNKNOWN”. I have made the changes in Nagios for all the services and all the services return value 2 expect Time Skew service.
Imran Khan.
jdalrymple
Skynet Drone
Re: Services issues
When you say time skew service you are referring specifically to your check_snmp_time check attached earlier? Did you make the change I suggested? In case you have not I have attached a modified version (using the adjustment I mentioned earlier) that does return critical when it cannot reach the snmp daemon.
[jdalrymple@localhost ~]$ ./check_snmp_time -H localhost -C public; echo $?
Timeout: No Response from localhost.
2
check_snmp_time.sh
(3.66 KiB) Downloaded 381 times
imran_khan
Re: Services issues
As per your suggestion, I have changed the time script usr/local/nagios/libexec/check_snmp_time.
Changed
exit 3
fi
to
exit 2
fi
When run the check_snmp_time script on localhost it returned value 2 means it is working fine after making changes but it is returning value 3 with Negate script for remote servers.
[root@NAGIOS libexec]# ./check_snmp_time -H localhost -C Community; echo $?
2
[root@NAGIOS ~]# /usr/local/nagios/libexec/negate -u CRITICAL /usr/local/nagios/libexec/check_snmp_time -H Server IP -C Community; echo $?
No data returned from command
3
3
Imran Khan.
jdalrymple
Skynet Drone
Re: Services issues
The idea is that you should no longer need to use negate to get the results you want. What is it you're trying to achieve with negate at this point?
Simply use the modified check in place without negate. Does that provide the results you want?
imran_khan
Re: Services issues
Got it. There is no need to use Negate for time script.
Thanks for your support.
Imran Khan.
