Services issues
imran_khan
Services issues
Post by imran_khan »
We have observed that services of all the servers are going in “UNKNOWN” section instead of “CRITICAL” when server go down.
It should show in “CRITICAL” section not in “UNKNOWN”. I am monitoring some services from using SNMP.
Imran Khan.
Re: Services issues
Post by Box293 »
Can you post example commands showing this behaviour.
What plugins are you using?
imran_khan
Re: Services issues
I am using check_snmp plugin. Here is the example.
Command:-
command_name space
command_line /usr/local/nagios/libexec/check_snmp -H $HOSTADDRESS$ -C $ARG1$ -o 1.3.6.1.4.1.2021.9.1.9.8 -w $ARG2$ -c $ARG3$
Service:-
use generic-service,srv-pnp ; Name of service template to use
host_name Example.com
service_description space
is_volatile 0
check_period 24x7
max_check_attempts 3
normal_check_interval 60
retry_check_interval 1
contact_groups windowsadm
notification_interval 120
notification_period 24x7
notification_options w,u,c,r
check_command space! Community_name!80!90
Imran Khan.
imran_khan
Re: Services issues
Any help?
Imran Khan.
Re: Services issues
Post by Box293 »
This can be defined in the next release of the Nagios Plugins.
/usr/local/nagios/libexec/check_snmp -H win2008r2-01 -C box293 -o 1.3.6.1.2.1.1.1.0 -w 80 -c 90 -t 30:CRITICAL
CRITICAL - Plugin timed out while executing system call
echo $?
2
Specifically this is the new feature:
-t 30:CRITICAL
You can deploy the current beta of the these plugins, check out this thread:
http://support.nagios.com/forum/viewtop ... 10#p124807
It would be great if you did deploy the beta plugins as this will help find any bugs before the next version gets released.
imran_khan
Re: Services issues
Mentioned command did not wrok.
Imran Khan.
Re: Services issues
Post by Box293 »
Box293 wrote:This can be defined in the next release of the Nagios Plugins.
Box293 wrote:You can deploy the current beta of the these plugins, check out this thread:
Did you deploy the beta release of Nagios Plugins?
-t 30:CRITCAL will only work in the beta version of the Nagios Plugins.
Alternatively you could also change your nagios.cfg:
# SERVICE CHECK TIMEOUT STATE
# This setting determines the state Nagios will report when a
# service check times out - that is does not respond within
# service_check_timeout seconds.  This can be useful if a
# machine is running at too high a load and you do not want
# to consider a failed service check to be critical (the default).
# Valid settings are:
# c - Critical (default)
# u - Unknown
# w - Warning
# o - OK
service_check_timeout_state=u
imran_khan
Re: Services issues
Is there any alternative solution?
What are the impact if I will add service_check_timeout_state=u paramter in Nagios configuration file (/usr/local/nagios/etc/nagios.cfg) as my Nagios server is in production and 400+ server are configured on it.
Imran Khan,
Re: Services issues
Post by Box293 »
You could also use negate.
This guide was written for XI but it holds true to core as well:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
imran_khan wrote:What are the impact if I will add service_check_timeout_state=u paramter in Nagios configuration file (/usr/local/nagios/etc/nagios.cfg) as my Nagios server is in production and 400+ server are configured on it.
Any services that timeout will display an unknown state instead of critical. There is no extra load placed on the system.
imran_khan
Re: Services issues
By using Netgate plugin I cannot solve this issue. Negates the status of a plugin (returns OK for CRITICAL and vice-versa).
When my server goes down then all the services should list in CRITICAL section not in UNKNOWN.
Imran Khan.
