No output on stdout) stderr: connection refused
Re: No output on stdout) stderr: connection refused
Commands typically go in to the commands.cfg file.
donnyforbes
Post by donnyforbes »
I thought so. I tried this below and it did not work so not sure if it has to go in a different place or not.
use linux-box ; Inherit default values from a template
host_name huey  ; The name or IP or remote server
alias RHEL 7.3 ; A longer name for the server
address 192.168.1.42 ; IP address of the remote server
check_ping -H 192.168.1.149 -w 10,2% -c 20,5% -t 5 ; ping to remote hosts
When doing this and restarting it would not start backup if failed. Does it go there or somewhere else. Do you have an example of this ???
What I am trying to get accomplished is when a server can't be ping it will send notification, right just trying to get the ping portion setup.
Post by dwhitfield »
I apologize if this has already been suggested, but it seems like you could really benefit from Nagios XI. You can download a 60-trial.
There are going to be some changes to the trials, but for now, you can use the free version for up to 7 hosts indefinitely.
There are a number of download options: https://www.nagios.com/downloads/nagios-xi/
donnyforbes
We do plan on getting XI, however we need to get it working and showing that it will work for our company and its needs that is why I am using the core version now.
I did find this in the commmand.cfg file
# SAMPLE HOST CHECK COMMANDS
# This command checks to see if a host is "alive" by pinging it
# The check must result in a 100% packet loss or 5 second (5000ms) round trip
# average time to produce a critical error.
# Note: Five ICMP echo packets are sent (determined by the '-p 5' argument)
# 'check-host-alive' command definition
        command_name    check-host-alive
        command_line    $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
I just need to know how to add this for each hosts that I have. We have to be notified when a hosts goes down.
donnyforbes
I think I figured it out. Thanks for all your help...
donnyforbes wrote:We do plan on getting XI, however we need to get it working and showing that it will work for our company and its needs that is why I am using the core version now.
This isn't the best strategy, IMO. If you are interested in XI, start the 60-day trial and show that it works from there. Editing config files in XI is not a thing. You are wasting a lot of time with Core if you plan to move to XI. If you need more than 60-days for a proof of concept, describe your requirements to Sales, and they may grant an extension.
