No output on stdout) stderr: connection refused
donnyforbes
Post by donnyforbes »
From nagios server
[root@nag etc]# /usr/local/nagios/libexec/check_nrpe -H 192.168.1.42
NRPE v3.1.0-rc1
From the remote hosts.
root@huey downloads]# /usr/local/nagios/libexec/check_nrpe -H localhost
NRPE v3.1.0-rc1
[root@huey downloads]# netstat -an |grep 5666
tcp        0      0 0.0.0.0:5666            0.0.0.0:*               LISTEN
tcp6       0      0 :::5666                 :::*                    LISTEN
Attached is the actual screenshot of what I am seeing. Just wondering if there are some configs files or something that I need to modify in order to get this to work.
donnyforbes
Re: No output on stdout) stderr: connection refused
Can someone give me some assistance with this? I am stuck and need to get this working? Not sure what it could be considering that those ports are open.
donnyforbes
From remote hosts...
[root@huey downloads]#  cat /etc/xinetd.d/nrpe
# default: off
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
    disable         = no
    socket_type     = stream
    port            = 5666
    wait            = no
    user            = nagios
    group           = nagios
    server          = /usr/local/nagios/bin/nrpe
    server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
    only_from       = 192.168.1.186
    log_on_success  =
Then verified that nrpe is running
[root@huey downloads]# lsof -i:5666
COMMAND   PID   USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
nrpe    55129 nagios    4u  IPv4 5871464      0t0  TCP *:nrpe (LISTEN)
nrpe    55129 nagios    5u  IPv6 5871465      0t0  TCP *:nrpe (LISTEN)
Is there something I am missing in a config file somewhere?
It is probably the firewall on the system blocking port 5666.
Search the internet for instructions on how to allow that port through your firewall.
donnyforbes
Here is my /usr/local/nagios/etc/nrpe.cfg
# Sample NRPE Config File
# Written by: Ethan Galstad ([email protected]) # # Last Modified: 2016-05-10 # # NOTES:
# This is a sample configuration file for the NRPE daemon.  It needs to be # located on the remote host that is running the NRPE daemon, not the host # from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# LOG FILE
# If a log file is specified in this option, nrpe will write to # that file instead of using syslog.
#log_file=${prefix}/var/nrpe.log
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the # syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID # number.  The file is only written if the NRPE daemon is started by the root # user and is running in standalone mode.
pid_file=/usr/local/nagios/var/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-privileged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface # and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
# LISTEN QUEUE SIZE
# Listen queue size (backlog) for serving incoming connections.
# You may want to increase this value under high load.
#listen_queue_size=5
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames # that are allowed to talk to the NRPE daemon. Network addresses with a bit mask # (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently # supported.
# Note: The daemon only does rudimentary checking of the client's IP # address.  I would highly recommend adding entries in your /etc/hosts.allow # file to allow only the specified host to connect to the port # you are running this daemon on.
#allowed_hosts=127.0.0.1,::1
allowed_hosts=127.0.0.1, 192.168.1.186
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients # to specify arguments to commands that are executed.  This option only works # if the daemon was configured with the --enable-command-args configure script # option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! *** # Read the SECURITY file for information on some of the security implications # of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=0
# BASH COMMAND SUBSTITUTION
# This option determines whether or not the NRPE daemon will allow clients # to specify arguments that contain bash command substitutions of the form # $(...).  This option only works if the daemon was configured with both # the --enable-command-args and --enable-bash-command-substitution configure # script options.
# *** ENABLING THIS OPTION IS A HIGH SECURITY RISK! *** # Read the SECURITY file for information on some of the security implications # of enabling this variable.
# Values: 0=do not allow bash command substitutions,
#         1=allow bash command substitutions
allow_bash_command_substitution=0
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the # command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! *** # Usage scenario:
# Execute restricted commmands using sudo.  For this to work, you need to add # the nagios user to your /etc/sudoers.  An example entry for allowing # execution of the plugins from might be:
# nagios          ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them) # without asking for a password.  If you do this, make sure you don't give # random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will # allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will # wait for a connection to be established before exiting. This is sometimes # seen where a network problem stops the SSL being established even though # all network sessions are connected. This causes the nrpe daemons to # accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEAK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have # a /dev/random or /dev/urandom (on purpose or because the necessary patches # were not applied). The random number generator will be seeded from a file # which is either a file pointed to by the environment valiable $RANDFILE # or $HOME/.rnd. If neither exists, the pseudo random number generator will # be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# SSL/TLS OPTIONS
# These directives allow you to specify how to use SSL/TLS.
# SSL VERSION
# This can be any of: SSLv2 (only use SSLv2), SSLv2+ (use any version),
#        SSLv3 (only use SSLv3), SSLv3+ (use SSLv3 or above), TLSv1 (only use
#        TLSv1), TLSv1+ (use TLSv1 or above), TLSv1.1 (only use TLSv1.1),
#        TLSv1.1+ (use TLSv1.1 or above), TLSv1.2 (only use TLSv1.2),
#        TLSv1.2+ (use TLSv1.2 or above)
# If an "or above" version is used, the best will be negotiated. So if both # ends are able to do TLSv1.2 and use specify SSLv2, you will get TLSv1.2.
# If you are using openssl 1.1.0 or above, the SSLv2 options are not available.
#ssl_version=SSLv2+
# SSL USE ADH
# This is for backward compatibility and is DEPRECATED. Set to 1 to enable # ADH or 2 to require ADH. 1 is currently the default but will be changed # in a later version.
#ssl_use_adh=1
# SSL CIPHER LIST
# This lists which ciphers can be used. For backward compatibility, this # defaults to 'ssl_cipher_list=ALL:!MD5:@STRENGTH' in this version but # will be changed to something like the example below in a later version of NRPE.
#ssl_cipher_list=ALL:!MD5:@STRENGTH
#ssl_cipher_list=ALL:!aNULL:!eNULL:!SSLv2:!LOW:!EXP:!RC4:!MD5:@STRENGTH
# SSL Certificate and Private Key Files
#ssl_cacert_file=/etc/ssl/servercerts/ca-cert.pem
#ssl_cert_file=/etc/ssl/servercerts/nagios-cert.pem
#ssl_privatekey_file=/etc/ssl/servercerts/nagios-key.pem
# SSL USE CLIENT CERTS
# This options determines client certificate usage.
# Values: 0 = Don't ask for or require client certificates (default)
#         1 = Ask for client certificates
#         2 = Require client certificates
#ssl_client_certs=0
# SSL LOGGING
# This option determines which SSL messages are send to syslog. OR values # together to specify multiple options.
# Values: 0x00 (0)  = No additional logging (default)
#         0x01 (1)  = Log startup SSL/TLS parameters
#         0x02 (2)  = Log remote IP address
#         0x04 (4)  = Log SSL/TLS version of connections
#         0x08 (8)  = Log which cipher is being used for the connection
#         0x10 (16) = Log if client has a certificate
#         0x20 (32) = Log details of client's certificate if it has one
#         -1 or 0xff or 0x2f = All of the above
#ssl_logging=0x00
# NASTY METACHARACTERS
# This option allows you to override the list of characters that cannot # be passed to the NRPE daemon.
# nasty_metachars="|`&><'\\[]{};\r\n"
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a # .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# COMMAND DEFINITIONS
# Command definitions that this daemon will run.  Definitions # are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name> # it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be # typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside # on the machine that this daemon is running on!  The examples below # assume that you have plugins installed in a /usr/local/nagios/libexec # directory.  Also note that you will have to modify the definitions below # to match the argument format the plugins expect.  Remember, these are # examples only!
# The following examples use hardcoded command arguments...
command[check_users]=/usr/local/nagios/libexec/check_users -w 5 -c 10 command[check_load]=/usr/local/nagios/libexec/check_load -r -w .15,.10,.05 -c .30,.25,.20 command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/hda1 command[check_zombie_procs]=/usr/local/nagios/libexec/check_procs -w 5 -c 10 -s Z command[check_total_procs]=/usr/local/nagios/libexec/check_procs -w 150 -c 200
# The following examples allow user-supplied arguments and can # only be used if the NRPE daemon was compiled with support for # command arguments *AND* the dont_blame_nrpe directive in this # config file is set to '1'.  This poses a potential security risk, so # make sure you read the SECURITY file before doing this.
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$ #command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$ #command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$ #command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
donnyforbes
when you say this?
Are you talking about the firewall on the nagios server, remote hosts, or are you talking about my watchguard firewall for my network?
The firewall on the Remote Hosts and if the Watchguard device is between the Nagios server and the remote hosts, it has to allow port 5666 through it.
The firewall on the Nagios server would nit have to be edited as it is initiating the connection to the remote hosts.
donnyforbes
This is the remote host -- It seems as the firewall ports are open
[root@huey etc]# lsof -i:5666
[root@huey etc]# netstat -an |grep 5666
[root@huey etc]#
you thinking maybe the system firewall?
Yes, I think the system firewall is blocking the inbound traffic.
Run this on the system as root and it should show you the ports that are allowed on your system.
service iptables status
donnyforbes
Alright so I created a rule on my firewall and open port 5666/tcp from any trusted -> any trusted. I have stopped and restart nagios. Is there anything else I need to do?
