Configure Exim MailServer Logs With NLS
rlinux57
Re: Configure Exim MailServer Logs With NLS
Post by rlinux57 »
[root@logs ~]# tail -n100 /var/log/elasticsearch/6db29f4d-70ef-4fce-b866-ac6deae349d2.log
[2016-02-12 01:29:12,634][INFO ][KnapsackService          ] add: plugin.knapsack.export.state -> []
[2016-02-12 01:29:12,634][INFO ][KnapsackExportAction     ] start of export: {"mode":"export","started":"2016-02-11T20:29:12.634Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}
[2016-02-12 01:29:12,634][INFO ][KnapsackService          ] update cluster settings: plugin.knapsack.export.state -> [{"mode":"export","started":"2016-02-11T20:29:12.634Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}]
[2016-02-12 01:29:12,634][INFO ][KnapsackExportAction     ] getting settings for indices [nagioslogserver]
[2016-02-12 01:29:12,634][INFO ][KnapsackExportAction     ] found indices: [nagioslogserver]
[2016-02-12 01:29:12,635][INFO ][KnapsackExportAction     ] getting mappings for index nagioslogserver and types []
[2016-02-12 01:29:12,636][INFO ][KnapsackExportAction     ] found mappings: [cf_option, node, reactor_server, query, _default_, snapshot, alert, email_template, commands, snmp_reactor, nrdp_server, user]
[2016-02-12 01:29:12,636][INFO ][KnapsackExportAction     ] adding mapping: cf_option
[2016-02-12 01:29:12,636][INFO ][KnapsackExportAction     ] adding mapping: node
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: reactor_server
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: query
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: _default_
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: snapshot
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: alert
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: email_template
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: commands
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: snmp_reactor
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: nrdp_server
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] adding mapping: user
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] getting aliases for index nagioslogserver
[2016-02-12 01:29:12,637][INFO ][KnapsackExportAction     ] found 0 aliases
[2016-02-12 01:29:12,639][INFO ][KnapsackExportAction     ] end of export: {"mode":"export","started":"2016-02-11T20:29:12.634Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}, packets = 35, total bytes transferred = 7196, rate = 1439.200000
[2016-02-12 01:29:12,639][INFO ][KnapsackService          ] remove: plugin.knapsack.export.state -> [{"mode":"export","started":"2016-02-11T20:29:12.634Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}]
[2016-02-12 01:29:12,639][INFO ][KnapsackService          ] update cluster settings: plugin.knapsack.export.state -> []
[2016-02-12 01:29:13,722][INFO ][KnapsackService          ] add: plugin.knapsack.export.state -> []
[2016-02-12 01:29:13,722][INFO ][KnapsackExportAction     ] start of export: {"mode":"export","started":"2016-02-11T20:29:13.722Z","path":"file:///store/backups/nagioslogserver/1455222552/kibana-int.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}
[2016-02-12 01:29:13,722][INFO ][KnapsackService          ] update cluster settings: plugin.knapsack.export.state -> [{"mode":"export","started":"2016-02-11T20:29:13.722Z","path":"file:///store/backups/nagioslogserver/1455222552/kibana-int.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}]
[2016-02-12 01:29:13,722][INFO ][KnapsackExportAction     ] getting settings for indices [kibana-int]
[2016-02-12 01:29:13,723][INFO ][KnapsackExportAction     ] found indices: [kibana-int]
[2016-02-12 01:29:13,723][INFO ][KnapsackExportAction     ] getting mappings for index kibana-int and types []
[2016-02-12 01:29:13,723][INFO ][KnapsackExportAction     ] found mappings: [dashboard]
[2016-02-12 01:29:13,724][INFO ][KnapsackExportAction     ] adding mapping: dashboard
[2016-02-12 01:29:13,724][INFO ][KnapsackExportAction     ] getting aliases for index kibana-int
[2016-02-12 01:29:13,724][INFO ][KnapsackExportAction     ] found 0 aliases
[2016-02-12 01:29:13,726][INFO ][KnapsackExportAction     ] end of export: {"mode":"export","started":"2016-02-11T20:29:13.722Z","path":"file:///store/backups/nagioslogserver/1455222552/kibana-int.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}, packets = 7, total bytes transferred = 2623, rate = 524.600000
[2016-02-12 01:29:13,726][INFO ][KnapsackService          ] remove: plugin.knapsack.export.state -> [{"mode":"export","started":"2016-02-11T20:29:13.722Z","path":"file:///store/backups/nagioslogserver/1455222552/kibana-int.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}]
[2016-02-12 01:29:13,726][INFO ][KnapsackService          ] update cluster settings: plugin.knapsack.export.state -> []
[2016-02-12 01:29:14,798][INFO ][KnapsackService          ] add: plugin.knapsack.export.state -> []
[2016-02-12 01:29:14,798][INFO ][KnapsackExportAction     ] start of export: {"mode":"export","started":"2016-02-11T20:29:14.798Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver_log.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}
[2016-02-12 01:29:14,798][INFO ][KnapsackExportAction     ] getting settings for indices [nagioslogserver_log]
[2016-02-12 01:29:14,799][INFO ][KnapsackService          ] update cluster settings: plugin.knapsack.export.state -> [{"mode":"export","started":"2016-02-11T20:29:14.798Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver_log.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}]
[2016-02-12 01:29:14,799][INFO ][KnapsackExportAction     ] found indices: [nagioslogserver_log]
[2016-02-12 01:29:14,799][INFO ][KnapsackExportAction     ] getting mappings for index nagioslogserver_log and types []
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] found mappings: [JOBS, MAINTENANCE, POLLER, SECURITY]
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] adding mapping: JOBS
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] adding mapping: MAINTENANCE
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] adding mapping: POLLER
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] adding mapping: SECURITY
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] getting aliases for index nagioslogserver_log
[2016-02-12 01:29:14,800][INFO ][KnapsackExportAction     ] found 0 aliases
[2016-02-12 01:29:15,545][INFO ][KnapsackExportAction     ] end of export: {"mode":"export","started":"2016-02-11T20:29:14.798Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver_log.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}, packets = 42756, total bytes transferred = 6584103, rate = 1316820.600000
[2016-02-12 01:29:15,546][INFO ][KnapsackService          ] remove: plugin.knapsack.export.state -> [{"mode":"export","started":"2016-02-11T20:29:14.798Z","path":"file:///store/backups/nagioslogserver/1455222552/nagioslogserver_log.tar.gz","node_name":"b1e300cf-f468-41ce-8d9c-301b97ead7a7"}]
[2016-02-12 01:29:15,546][INFO ][KnapsackService          ] update cluster settings: plugin.knapsack.export.state -> []
[root@logs ~]# tail -n100 /var/log/logstash/logstash.log
[root@logs ~]# tail /var/log/logstash/logstash.log
hsmith
Agent Smith
Post by hsmith »
There's not much information in there that helps us. What's the output of service logstash status ? If possible, I recommend you sign up for the Quickstart that I sent you on the previous post. This is a free one hour session in which we can help you learn the product/troubleshoot any issues that you may be experiencing.
Former Nagios Employee.
me.
rlinux57
Post by rlinux57 »
[root@logs ~]# service logstash status
Logstash Daemon dead but pid file exists
Okay i'll sign up
hsmith
Agent Smith
Post by hsmith »
As far as the error you posted, can you do the following?
service logstash stop
ps -ef | grep logstash
me.
rlinux57
Post by rlinux57 »
[root@logs ~]# service logstash stop
Stopping Logstash Daemon:                                  [FAILED]
[root@logs ~]# ps -ef | grep logstash
root     10998 31977  0 03:28 pts/0    00:00:00 grep logstash
hsmith
Agent Smith
Post by hsmith »
Can you run the following?
rm -f /run/logstash/logstash*
service logstash start
me.
rlinux57
Post by rlinux57 »
[root@logs ~]# rm -f /run/logstash/logstash*
[root@logs ~]# service logstash start
Starting Logstash Daemon: WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
                                                           [  OK  ]
Logstash Daemon (pid  12363) is running...
hsmith
Agent Smith
Post by hsmith »
Wow. And there's still nothing in /var/log/logstash/logstash.log? What about /var/log/messages?
me.
rlinux57
Post by rlinux57 »
[root@logs ~]# cat /var/log/logstash/logstash.log
{:timestamp=>"2016-02-12T03:40:03.656000+0500", :message=>"Error: No config files found: /usr/local/nagioslogserver/logstash/etc/conf.d/*\nCan you make sure this path is a logstash config file?"}
{:timestamp=>"2016-02-12T03:40:03.660000+0500", :message=>"You may be interested in the '--configtest' flag which you can\nuse to validate logstash's configuration before you choose\nto restart a running system."}
[root@logs ~]# tail -n50 /var/log/messages
Feb  9 12:51:58 logs kernel: Kernel logging (proc) stopped.
Feb  9 12:51:58 logs rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="520" x-info="http://www.rsyslog.com"] exiting on signal 15.
Feb  9 12:52:10 logs kernel: imklog 5.8.10, log source = /proc/kmsg started.
Feb  9 12:52:10 logs rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="513" x-info="http://www.rsyslog.com"] start
Feb  9 12:52:10 logs xinetd[566]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Feb  9 12:52:10 logs xinetd[566]: Started working: 0 available services
Feb  9 12:52:10 logs ntpd[575]: ntpd [email protected] Mon Jan 25 14:08:27 UTC 2016 (1)
Feb  9 12:52:10 logs ntpd[576]: proto: precision = 0.046 usec
Feb  9 12:52:10 logs ntpd[576]: 0.0.0.0 c01d 0d kern kernel time sync enabled
Feb  9 12:52:10 logs ntpd[576]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Feb  9 12:52:10 logs ntpd[576]: Listen and drop on 1 v6wildcard :: UDP 123
Feb  9 12:52:10 logs ntpd[576]: Listen normally on 2 lo 127.0.0.1 UDP 123
Feb  9 12:52:10 logs ntpd[576]: Listen normally on 3 venet0:0 51.254.56.78 UDP 123
Feb  9 12:52:10 logs ntpd[576]: Listen normally on 4 lo ::1 UDP 123
Feb  9 12:52:10 logs ntpd[576]: Listening on routing socket on fd #21 for interface updates
Feb  9 12:52:10 logs ntpd[576]: 0.0.0.0 c016 06 restart
Feb  9 12:52:10 logs ntpd[576]: 0.0.0.0 c012 02 freq_set kernel 0.000 PPM
Feb  9 12:52:10 logs ntpd[576]: 0.0.0.0 c011 01 freq_not_set
Feb  9 12:52:10 logs ntpd[576]: cap_set_proc() failed to drop root privileges: Operation not permitted
Feb  9 12:52:10 logs saslauthd[587]: detach_tty      : master pid is: 587
Feb  9 12:52:10 logs saslauthd[587]: ipc_init        : listening on socket: /var/run/saslauthd/mux
Feb  9 14:03:44 logs rsyslogd-2066: could not load module '/lib64/rsyslog/lmnsd_ptcp.so', dlopen: /lib64/rsyslog/lmnsd_ptcp.so: failed to map segment from shared object: Cannot allocate memory
 [try http://www.rsyslog.com/e/2066 ]
Feb  9 14:03:46 logs kernel: [1975726.697697] Out of memory in UB 147: OOM killed process 618 (java) score 0 vm:4718000kB, rss:2615528kB, swap:0kB
Feb  9 14:04:20 logs init: console main process (747) killed by TERM signal
Feb  9 14:04:20 logs init: tty2 main process (748) killed by TERM signal
Feb  9 14:04:21 logs saslauthd[587]: server_exit     : master exited: 587
Feb  9 14:04:23 logs xinetd[566]: Exiting...
Feb  9 14:04:24 logs init: Disconnected from system bus
Feb  9 14:04:24 logs kernel: Kernel logging (proc) stopped.
Feb  9 14:04:24 logs rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="513" x-info="http://www.rsyslog.com"] exiting on signal 15.
Feb  9 14:04:48 logs kernel: imklog 5.8.10, log source = /proc/kmsg started.
Feb  9 14:04:48 logs rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="512" x-info="http://www.rsyslog.com"] start
Feb  9 14:04:49 logs xinetd[566]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Feb  9 14:04:49 logs xinetd[566]: Started working: 0 available services
Feb  9 14:04:49 logs ntpd[575]: ntpd [email protected] Mon Jan 25 14:08:27 UTC 2016 (1)
Feb  9 14:04:49 logs ntpd[576]: proto: precision = 0.054 usec
Feb  9 14:04:49 logs ntpd[576]: 0.0.0.0 c01d 0d kern kernel time sync enabled
Feb  9 14:04:49 logs ntpd[576]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Feb  9 14:04:49 logs ntpd[576]: Listen and drop on 1 v6wildcard :: UDP 123
Feb  9 14:04:49 logs ntpd[576]: Listen normally on 2 lo 127.0.0.1 UDP 123
Feb  9 14:04:49 logs ntpd[576]: Listen normally on 3 venet0:0 51.254.56.78 UDP 123
Feb  9 14:04:49 logs ntpd[576]: Listen normally on 4 lo ::1 UDP 123
Feb  9 14:04:49 logs ntpd[576]: Listening on routing socket on fd #21 for interface updates
Feb  9 14:04:50 logs ntpd[576]: 0.0.0.0 c016 06 restart
Feb  9 14:04:50 logs ntpd[576]: 0.0.0.0 c012 02 freq_set kernel 0.000 PPM
Feb  9 14:04:50 logs ntpd[576]: 0.0.0.0 c011 01 freq_not_set
Feb  9 14:04:50 logs ntpd[576]: cap_set_proc() failed to drop root privileges: Operation not permitted
Feb  9 14:04:50 logs saslauthd[587]: detach_tty      : master pid is: 587
Feb  9 14:04:50 logs saslauthd[587]: ipc_init        : listening on socket: /var/run/saslauthd/mux
hsmith
Agent Smith
Post by hsmith »
That's a problem. What's the output of this command?
ls -l /usr/local/nagioslogserver/logstash/etc/conf.d/
me.
