Config error for Exchange server and Network Switch
dmanem
Re: Config error for Exchange server and Network Switch
Post by dmanem »
I set the values based on your suggestions. Now the write config command is not showing any errors. I have not run the monitoring wizard configuration yet as the hosts are still out of sync. I am guessing they take time to get in sync. Now I have so many hosts without a proper parent node defined. As I have 500+ hosts is there a easier way to configure them than to go to each node separately and do so.
After the hosts are in sync I will run the monitoring wizard and will update you on the result.
Thank you very much for your help. I appreciate it.
They will show synced once you successfully apply configuration.
Off the top of my head, I don't have any easy way to set the parents for all of these hosts.
dmanem
Post by dmanem »
I am trying to configure my Stack Switch and I am having issues again. When I am configuring the switch, the steps do not include the "Check period" and "Notification period" and they are required when configuring services on the switch. Is that a reason the configuration is failing? I have around 900 services for this switch and I cannot change those settings individually. Attached is the config snapshot with the errors.
Thank you.
We recently ran into a similar issue with a different client that contained Nagios illegal characters as this does.
I am attaching a new Switch/Router wizard. Upload it to your server through Admin -> Manage Config Wizards
You will need to remove these through Configure -> CCM then re-run the wizard.
The new wizard will strip out (){}[]
dmanem
Post by dmanem »
Thank you. That worked better.
