no change after restarting !!
But i find out in the Nagiosxi GUI in Processes the 'External Commands' process ist RED and not working.
In the nagios.cfg the external command switch is enabled...?????
Update NagiosXi to 2011R3.1
Re: Update NagiosXi to 2011R3.1
Does a /usr/local/nagios/var/rw/nagios.cmd exist on your system?
Nicholas Scott
Yes there is this file:
srw-rw---- 1 nagios nagcmd 0 Aug 3 18:20 live
prw-rw---- 1 nagios nagcmd 0 Aug 3 18:20 nagios.cmd
And when i came in the Office this morning no service checks where executed and i find the error "out of notification period"
i attache th nagios.log file .
I have the default xi_timeperiod_24x7 activated for all hosts and services.
Where are you seeing "out of notification period" I looked through the attached log but could not find it.
Sorry for my late reply but i was not available in this day's.
This "out of notification period " came from the Check_MK interface (because nagiosXI interface is still not updating) and was an error in the time periods
config file, there was a day missing. The Error always happen on Wednesday and the service resumed always on Thursday.
Does this behavior exist if you (temporarily) disable the check_mk event broker in the nagios.cfg and restart nagios?
This behavior is the same if i deactivate the event Broker from Check_mk
I honestly can't say where check_mk is getting it, are you seeing it in the nagios interface anywhere?
Monitoring Process
Monitoring Engine Process
Metric
Value
Action
Process Info
Process State [Running]
[Stop]
[Restart]
Process Start Time 2012-06-06 15:41:57
Total Running Time 83d 1h 17m 10s
Process ID 11840
Process Settings
External Commands [Disabled]
Active Service Checks [Enabled] [Disable]
Passive Service Checks [Enabled] [Disable]
Active Host Checks [Enabled] [Disable]
Passive Host Checks [Enabled] [Disable]
Notifications [Enabled] [Disable]
Event Handlers [Enabled] [Disable]
Flap Detection [Enabled] [Disable]
Performance Data [Enabled] [Disable]
Service Obsession [Enabled] [Disable]
Host Obsession [Enabled] [Disable]
Last Updated: 2012-08-28 16:59:07
Monitoring Engine Event Queue
Scheduled Events Over Time
This is the Monitor Process Screen with external command disabled (and with a red dot)
but all the switches in nagios.cfg are switched to anabled. How i can get the external command enabled again??
Thank you
Metric
Value
Action
Process Info
[Stop]
[Restart]
Process ID 11840
Process Settings
Thank you
