nagiosxi stuck at applying configuration
Re: nagiosxi stuck at applying configuration
Post by slansing »
We originally had it marked with an asterisk. The issue is, the CCM won't let you save the configuration if you have a required field that is empty, users were applying templates to their hosts/services that had the field filled out but the CCM was not accepting that and was instead forcing them to place an integer in the field to save it.
