Using NRPE for windows server
skypete
Post by skypete »
where would this be located again is that service command right?
skypete
Post by skypete »
host_name Testserver1
service_description Print Spooler
check_command check_nrpe!check_process!process=spoolsv.exe!show-all
max_check_attempts 1
event_handler restart-service
check_interval 3
retry_interval 1
check_period 24x7
notification_interval 60
notification_period 24x7
contacts nagiosadmin
_SERVICE Spooler
no it's a command you defined with a name restart-service
skypete
Post by skypete »
This where i copied it too
# NOTE: The following 'check_...' commands are used to monitor services on
# both local and remote hosts.
# 'restart-service' command definition
command_name restart-service
command_line $USER1$/restart_service.sh $SERVICESTATE$ $HOSTADDRESS$ $_SERVICESERVICE$T$
npolovenko
Post by npolovenko »
@skypete, Looks like you haven't replaced the "restart-service" command definition(see my post on the page#6).
To:
Please replace the command and then restart the nagios service with:
service nagios restart
Let us know if the event handler starts working.
You have a typo there...
lets replace this
with this
Then it should work
skypete
Post by skypete »
Im sorry still not working.
skypete wrote:Im sorry still not working.
Please copy and paste the command out of your config again..
Please verify you restarted nagios.
Please describe how you tested that it is working (e.g. how long you waited until after you stopped the service)
