Using NRPE for windows server
skypete
Post by skypete »
hello i am new to nagios core was asking if someone could please help me and point me in the right direction.I am trying to use latest nrpe and ubuntu 16.04 could someone please explain on how to get nrpe function working to use with windows servers it is very complicated. i have tried many of the tutorials on nagios site and cannot seem to get it working. could someone please help me on this i have been stuck for quite some time.
bolson
Post by bolson »
Have you installed NSClient++ on the Windows host? Any installation issues? Can you run the following command from you ubuntu host and post the result:
telnet <ip_addr_of_windows_host> 5666
skypete
Post by skypete »
Hi thank you for the reply i have installed it on win 2012 server. Let me try that command and thank you for you help.
npolovenko
Post by npolovenko »
@skypete, We need some more information to be able to help you. Can you describe the steps you took to install NRPE and what issues you've encountered?
Post by dwhitfield »
So, I think you already answered @npolovenko's question. You installed NSClient, which installed NRPE. Is that correct?
If so, please attach your NSC.ini or NSClient.ini.
What version of NSClient are you using? What error messages, if any are you getting? Also, the output of the command @bolson asked for yesterday would still be useful.
skypete
Post by skypete »
still not working is there a step by step guide on how to setup and install on NRPE on nagios core for window servers?
Please attach your NSC.ini or NSClient.ini.
Most of our documentation is written for XI, but it should help you get your NSClient.ini set up properly: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
skypete
Post by skypete »
Standby i will get you that info and thank you.
Sounds good. Please note, we will have modified office hours next week for New Year's.
skypete
Post by skypete »
Here is my Ini file as requested and the screenshot of the command you asked me to run. Also forgot to mentioned i did not add the window host to a cfg file for hosts and services that is what I am stuck with now. Also the version I am using version NSCP-0.5.1.44-x64
nsclient.ini
(1001 Bytes) Downloaded 1155 times
