Hello.
We use Active Directory auth in Nagios XI, which works pretty well, but as I understand Core Config Manager use separate authentication method. Can we user the same AD auth for the CCM ?
CCM Auth
Re: CCM Auth
This is currently not supported though could be feasible, you can submit a feature request to:
http://tracker.nagios.com/
And a developer will take a look at the idea!
Re: CCM Auth
We are evaluating XI, and would also like to see 1 login for both front end and the CCM. Barring that, CCM being pointed to AD so we can keep our SSO intact. As you stated, I'll visit the tracker and put in a request.
thanks,
-Ted
thanks,
-Ted
Re: CCM Auth
Thank you for submitting the feature request! We will look into this as it sounds it may not be too difficult to integrate.
