I tried to monitor HTTPS website by using check_http. I can run through terminal and it results "OK" status. Following command is used,
(Sample command)
#./check_http -H api.test.com -u "https://api.test.com/api2.0/checks/" -k "App-Key:tlhgfg34548uhd2h7jjgvs5qjhhmcvw" -a "[email protected]:test@123" -S -t 120
But in Nagios UI, it results "UNKNOWN" status with following error,
check_http: Invalid option - Valid values for SSL Version are 1 (TLSv1), 2 (SSLv2) or 3 (SSLv3)
My command definition is,
command_name check_monitor_page
command_line $USER1$check_http -H api.test.com -u "https://api.test.com/api2.0/checks/" -k "App-Key:tlhgfg34548uhd2h7jjgvs5qjhhmcvw" -a "[email protected]:test@123" -S -t 120
Where & what I missed, how can I resolve this?
Problem on check_http(s) usage
Re: Problem on check_http(s) usage
You are missing the SSL version number after the "-S" switch. Have youtried setting to 1,2 or 3?prabakaran wrote:command_line $USER1$check_http -H api.test.com -u "https://api.test.com/api2.0/checks/" -k "App-Key:tlhgfg34548uhd2h7jjgvs5qjhhmcvw" -a "[email protected]:test@123" -S -t 120
-S, --ssl=VERSION
Connect via SSL. Port defaults to 443. VERSION is optional, and prevents
auto-negotiation (1 = TLSv1, 2 = SSLv2, 3 = SSLv3).
