Acknowledgement not working
Dear expert , we are running nagiosXI 2012R1.5b , i have an admin access still Acknowledgement feature not working what could be the issue ? when i do it it 's accepting and giving message successfully done but it is not reflecting to any host and services.
Re: Acknowledgement not working
Can you access the Admin panel and make sure there aren't any subsystem jobs in the red?
Can you post the output from the following command?
ls -l /usr/local/nagios/var/rw
i have checked all admin panels component status are green , and
[root@masterxi1 ~]# ls -l /usr/local/nagios/var/rw
total 0
prw-rw---- 1 nagios nagcmd 0 Apr 11 16:49 nagios.cmd
Regards..
total 0
Regards..
Run the following command and show the output of it:
cat /etc/group | grep nagBe sure to check out our Knowledgebase for helpful articles and solutions!
sreinhardt
- -fno-stack-protector
Do you see any error messages when tailing log files and attempting to ack something?
tail -f /var/log/httpd/access_log
tail -f /var/log/httpd/error.log
Do you see the comment left from prior acknowledgements, especially since it has not been working, on the service or host detail page?
Is selinux enabled? "sestatus"
it is working now, we have not done any changes on system and application what could be the reason ?
