Problems installing Nagios XI
rks
Post by rks »
Env:
[root@maya-app-01-s nagiosxi]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 5.5 (Tikanga)
[root@maya-app-01-s nagiosxi]# uname -a
Linux maya-app-01-s.cisco.com 2.6.18-238.9.1.el5 #1 SMP Fri Mar 18 12:42:39 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
Nagios XI version:
version 2012 R1.7, source installation on a clean Linux VM (xi-2012r1.7.tar)
Problem:
I extracted xi-2012r1.7.tar in /tmp and started install as follows:
# cd /tmp
# tar xf xi-2012r1.7.tar
# cd nagiosxi
# ./fullinstall
The installation fails with the message:
"Yum was not properly prepared - run previous script"
The install.log is given below.
Could you please suggest a resolution to this?
Install.log:
Nagios XI Installation Log
DATE: Sat Apr 13 02:00:35 GMT 2013
DISTRO INFO:
RedHatEnterpriseServer
5.5
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=2012R1.7
major=2012
minor=R1.7
releasedate=2013-03-27
release=307
Configuring Yum...
WARNING: This script will remove existing RPMs installed on this
         system, which may result in existing applications being
         removed!
Do you want to continue? [y/N]: RESP: Y
Exiting
The full installation transcript is as follows:
  [root@maya-app-01-s nagiosxi]# ./fullinstall
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat.  Do NOT use this on a system that has been tasked with other purposes or has an existing install of
Nagios Core.  To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-yum'...
Configuring Yum...
         removed!
Do you want to continue? [y/N]: Y
RESP: Y
Exiting
RESULT=0
Running './1-prereqs'...
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
Re: Problems installing Nagios XI
Post by slansing »
Are you behind a proxy? If so make sure you follow this:
http://support.nagios.com/wiki/index.ph ... th_Proxies
