Question about publishing apps monitored by Nagios
tgfde
Post by tgfde »
Is there a way to publish what Nagios is monitoring without the user loggig into the UI?
Setup:
Nagios XI 2011R2.2
Cent OS 6
vmWare
tgfde
sreinhardt
-fno-stack-protector
Re: Question about publishing apps monitored by Nagios
Post by sreinhardt »
What do you mean by publish? You would like them to be able to see hosts and services without having a valid login?
abrist
Red Shirt
Post by abrist »
Are you asking for a list of what is being monitored, the current active status of monitored systems, or the results of checks?
tgfde
Post by tgfde »
I would like them to be able to see hosts and services without having a valid login.
Thanks.
abrist
Red Shirt
Post by abrist »
Are you looking for certain bits of information on a separate web page? Or emailed reports? What is the use case or targeted implementation?
tgfde
Post by tgfde »
Certain information on a web page that gets dynamically updated with the status of the service/host.
Thanks.
2 ways.
1. you can get the data in XML format to integrate using the Backend API URL component
Admin -> Manage Components -> Backend API URL -> edit
2. Would be to create a read-only user account, then you can get the ticket from the Backend API URL and you can tack those on to most URL's in XI to auto-login
for example:
/nagiosxi/includes/components/xicore/status.php?show=services&hoststatustypes=2&servicestatustypes=28&serviceattr=10&username=nagiosadmin&ticket=q6jjimi4
tgfde
Post by tgfde »
For option 2, can you explain further? What do yo mean by ticket?
FYI - I don't have Backend API URL installed yet as a component.
Thanks.
You can read more about the Nagios XI Backend API here:
http://assets.nagios.com/downloads/nagi ... nd_API.pdf
...and download the component.
tgfde
Post by tgfde »
Ok installatio of backend api is complete and tested ok.
However I'm having trouble viewing the services status. Below is what Im using:
https://nagiosxi.dev.tgslc.org/nagiosxi ... 53r8cdh66e [/b]
thanks,
Frederick
