Old cfg files
bliinfo0
Old cfg files
Post by bliinfo0 »
I have changed all config names in services to a new name. After appling configuration, I can still see a cfg file with old config name in /usr/local/nagios/etc/services. Will this cause any problem? What is the best way to clean the cfg file with old confg name?
abrist
Red Shirt
Re: Old cfg files
Post by abrist »
Have you "applied configuration" yet? What version of XI are you running?
bliinfo0
Re: Old cfg files
Post by bliinfo0 »
Yes, I did "applied configuration". Noticed all cfg files were updated with new time stamp expept the old one. We are running 2012R1.2.
Re: Old cfg files
Post by slansing »
When you remove the service from the CCM and apply configuration does it come back? If so please follow these steps for ghost host/service removal:
http://support.nagios.com/wiki/index.ph ... t_Hosts.29
