Regards
Html output on Status Notification Field
Is possible to made clickable that link
Regards
Regards
Re: Html output on Status Notification Field
Can you show us a screenshot of an example?
Here to you
Go to Admin -> Manage System Config
check "Allow HTML Tags in Host/Service Status"
