Error adding config access
BanditBBS
Post by BanditBBS »
Trying to add someone to core config manager and getting an error:
Error while inserting data into the database:
Unknown column 'locale' in 'field list'
When trying to copy an existing I get this:
Error while inserting the data to the database:
Unknown column '' in 'field list'
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Error adding config access
What version of XI are you running?
BanditBBS
Post by BanditBBS »
scottwilkerson wrote:What version of XI are you running?
Latest, 2012 1.7
Run the following commands:
mysql -pnagiosxi nagiosql
ALTER TABLE tbl_user ADD COLUMN locale VARCHAR(6) DEFAULT 'en_EN';
\q
Hope this helps.
BanditBBS
Post by BanditBBS »
lmiltchev wrote:Run the following commands:
\q
Hope this helps.
I can now add a new one, but can not copy and existing one. That is no big deal, just wanted to make sure the issue was known.
abrist
Red Shirt
Post by abrist »
This was a change applied by our upgrade script. Maybe your version was previously detected incorrectly during an upgrade and the column was not created. Thanks for the heads up.
