In my "Check_xi_OracleQuery", SQL query is too long and after saving that, half of query is automatically placed in $ARG2$, that gives "OUTPUT: UNKNOWN - got no valid response for ...." error, can anybody help me how to concatenate ARG1$ & ARG2 or if there is any other way to do so?
-connect xxxxxx --username xxxxx --password "xxxxx" --encode --mode sql --name="select count(1) as count from MyTable1 mt1, MyTable2 mt2 where mt1.id=mt2.mti_id and xxxxxxxxxxx so on.................." --name2="Total" --warning 1 --critical 2
bold and highlighted query is too long in my case and that is splitted by nagios in $ARG2$, please suggest if there is any other way to fix this issue.
Thanks in advance
Regards
Ali
Query too long for "Check_xi_OracleQuery"
sreinhardt
- -fno-stack-protector
Re: Query too long for "Check_xi_OracleQuery"
By default the differences in args being submitted to a check will have a space between them. I would suggest either modifying the command in CCM to remove the space, or the better suggestion would be to duplicate the check_xi_oraclequery to a unique check where your query is manually added to the command instead of being an argument(s).
aliprince12
Hello sreinhardt,
Apparently there are no extra spaces in my query, if i took you correct perhaps query can be longer than i have written. Can you write how can i duplicate Check_xi_oracle query, or from where i can find step by step process of your second suggestion?
Thank you.
Regards
Ali
Thank you.
Regards
Ali
sreinhardt
Certainly! What you would want to do, more than likely as your situation may vary somewhat. Start by going to Configure->Core Configure Manager->Commands
Search for Check_xi_OracleQuery and copy it. (the little double sheet of paper icon to the far right, between the wrench and red X)
Use the wrench icon to modify the new Check_xi_OracleQuery_copy_1 as such:
Command Name: Check_xi_OracleQuery_Unique (or any other name you prefer)
Command Line: Alter only the end of this line. Submit your query string in, you will have to see if it needs quotes or not, in place of $ARG1$, then append a space and $ARG1$ after your query. This way you can still use $arg1$ to add warning or other parameters to your query.
Active: Check this box
Hit save, then apply configuration. Finally go into the service check you are having issues with. Change the check command used, upper right, to the check_xi_OracleQuery_Unique check. Also alter $arg1$ so that your query is removed and only warning, critical or other parameters are shown.
