SQL Error [ndoutils] after partition copy
intelXIadmin
Post by intelXIadmin »
I had to decrease the size of a partition on Nagios XI, Redhat 6.4. The system came up just fine after the copy but now I have an error message that reads:
SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus'
I don't mind resetting the database if necessary since this just is going into production.
Regards,
Randy.
Re: SQL Error [ndoutils] after partition copy
Post by slansing »
Locking as there is a customer section thread open on the same topic.
