I am getting this error message after logging into our server today. No servers are showing up under any of the active views, like tactical overiew.
[ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus' SQL: SQL Error
Regards,
Randy.
intelXIadmin
Re: [ndoutils] : Incorrect file format 'nagios_servicestatus
1. Did this machine experience an unexpected loss of power?
2. Do you have backups?
3. Have you tried running the sql repair script?
intelXIadmin
oops, I fogot to mention versions:
1. OS - Redhat 6.4
2. NagiosXI - 2012R1.8
1. Did this machine experience an unexpected loss of power? Yes
2. Do you have backups? Not of the database
3. Have you tried running the sql repair script? Yes
Now, if I was to lose all the historical data it wouldn't be a problem at all. I just don't want to lose the configurations.
1. OS - Redhat 6.4
By default XI systems have this DB backed up in
/store/backups/mysql/daily/nagios
/store/backups/mysql/weekly/nagios
/store/backups/mysql/monthly/nagios
Do you have these?
Do you have these?
intelXIadmin
intelXIadmin
I see the files. I did not create them using the backup script. Are they tar files, or just gzip files? How are they restored?
Regards,
Randy.
Regards,
Randy.
they are just gzip, and are created on a daily cron, here is an example restore of the nagios DB
[root@localhost nagios]# cd /store/backups/mysql/daily/nagios
[root@localhost nagios]# ls -l
total 28264
-rw-r--r-- 1 root root 4421384 Apr 12 07:00 nagios_2013-04-12_07h00m.Friday.sql.gz
-rw-r--r-- 1 root root 4692986 Apr 17 07:00 nagios_2013-04-17_07h00m.Wednesday.sql.gz
-rw-r--r-- 1 root root 4789457 Apr 18 07:00 nagios_2013-04-18_07h00m.Thursday.sql.gz
-rw-r--r-- 1 root root 4941059 Apr 21 07:00 nagios_2013-04-21_07h00m.Sunday.sql.gz
-rw-r--r-- 1 root root 4998263 Apr 22 07:00 nagios_2013-04-22_07h00m.Monday.sql.gz
-rw-r--r-- 1 root root 5084448 Apr 23 07:00 nagios_2013-04-23_07h00m.Tuesday.sql.gz
[root@localhost nagios]# gunzip nagios_2013-04-23_07h00m.Tuesday.sql.gz
[root@localhost nagios]# cat nagios_2013-04-23_07h00m.Tuesday.sql | mysql -pnagiosxi nagios-
intelXIadmin
I was able to resolve this using a Nagiosxi backup. I run the restore procedure.
Excellent, thank you for letting us know.
