i have trouble setting up nagios monitoring for my database 10.2.0.4 on HPUX 11.11
the instant client on Nagios server is 11gR2 and i am monitoring a database 10.2.0.4
i can ssh from nagios server and also can do sqlplus using the tns from nagios xi server to the 10g host...
but the plugin times out while checking from nagios...
can you provide us with some solution
Oracle 10.2.0.4 database monitoring from nagios xi
maxwellmiranda
Re: Oracle 10.2.0.4 database monitoring from nagios xi
What full check command are you attempting?
Have you tried using the command right from the cli to verify it works before moving the check into XI?
maxwellmiranda
the commandline command times out too
Is the port open and listening for the XI server on the HPUX machine?
