Can the "Disable notifications" option be removed from NagiosXi users, or at least limit the option to the nagiosadmin?
Eddie
Disable "Disable notifications"
Re: Disable "Disable notifications"
You can remove the option for specific users to "Can access advanced features," this is controlled via a checkbox under Admin > Manage Users > "User's name" > Can access advanced features "check to disable."
