I follow simple steps from guides all over the web:
1. add an user to Nagios via command htpasswd htpasswd.users username
2. in cgi.cfg file add this user to lines
authorized_for_system_information=nagiosadmin, username
authorized_for_configuration_information=nagiosadmin, username
authorized_for_system_commands=nagiosadmin, username
authorized_for_all_services=nagiosadmin, username
authorized_for_all_hosts=nagiosadmin, username
authorized_for_all_service_commands=nagiosadmin, username
authorized_for_all_host_commands=nagiosadmin, username
3. restart nagios3 service, even restart apache2 service
but when I try to list anything from nagios web interface it still gives me this annoying message:
It appears as though you do not have permission to view information for any of the services you requested...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file.
Where could be a problem please?
Adding an user problem
Re: Adding an user problem
Locking this thread as a double post..
