I recently upgraded to 3.4.4 from the venerable 3.2.X releases and there has been a big change in behavior: NSCA stops accepting connections after I stop and restart Nagios. Stopping and restarting NSCA fixes this.
Anybody else seen this? Nagiosd and NSCA used to be able to operate more or less independently.
This is a bog-standard install on a bog-standard Centos 6.3 host.
Thanks in advance, --w
NSCA stops accepting connections when Nagios is restarted
Re: NSCA stops accepting connections when Nagios is restarte
What version of NSCA are you running? (host and server)
2.7.2.
I'll try upgrading to 2.9.1 ....
Let us know if you have the same issues with the newer version.
OK, finally upgraded to 2.9.1. It does not have the above problem, it can be stopped and restarted independently of nagios, and vice versa.
Excellent, let us know if you run into any more issues with this.
